Ground Water Around Lolly Column - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-27-2012, 11:40 AM   #1
ground water around lolly column
Can I seal the area around the base of a lolly column in my basement where water during heavy rains enters?
wallys is offline   Reply With Quote
Old 12-27-2012, 04:42 PM   #2
Rewards Points: 12,882
Sure sounds like someone added it without a footing under it to support it.
Old 12-27-2012, 05:30 PM   #3
GBrackins's Avatar
Rewards Points: 2,108
a photo may aid in providing useful advise .... Welcome to the Forum!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 12-27-2012, 06:16 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 906
+1
A picture is always worth a thousand words in these forums. There is quite a bit of variability when it comes to terminology.
Is there any sump/weeping tile in the home? That much moisture under the slab is never a good thing.
Old 12-28-2012, 08:18 AM   #5
Rewards Points: 4,454
understanding this problem's easier when you compare your very fine home's bsmt to a ship's hull below the waterline,,, yes, you can stop this leak however whatever mtl you select must resist infiltrating water pressure,,, once having stopped that leak, where will it appear next ? a crack in the floor, a corner, or somewhere up the bsmt wall ? stopping that particular leak won't resolve the basic problem,,, pay attn to the post re sump, pump, draintile
not that it will help much at this late date but be sure your foundation's backfill slopes 6' our & 6" down from where grade meets bsmt walls - downspout drainage is also important
Old 12-28-2012, 04:22 PM   #6
Rewards Points: 334
Footing around these columns and the rest of the slab are often poured separately. So the cold joint makes the weak point where water can push through. If every heavy rain is pushing through, the column is also rusting that much quicker and will be compromised in the future. There is nothing you can do from the top to handle the leak.
You really need more info on the layout of your house so you can address the ground water issues. If outside land grading does not help, next simplest may be to have a sump pit, either inside or out. Water collecting under your slab "may" drain into the sump.
carpdad is offline   Reply With Quote
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 09:44 PM
Adding ground to electric water heater tadc Electrical 8 03-05-2012 09:14 PM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 09:17 PM
Basement bath plumbing rough in allowing ground water to enter VooDu Plumbing 1 01-07-2010 02:09 PM
water meter ground wire jumper not needed? windowguy Electrical 13 07-21-2009 06:37 PM
