Old 05-27-2010, 07:59 PM   #1
Ground level deck - screws or bolts?
I am building a ground level deck to extend the size of my patio. 8' of the deck is over the old patio. 7.5' of the deck is over ground. I used 2x4s as sleepers that run the full length of the deck. The 2x4s set on the patio. Pillars were poured over the ground area and extend above the ground about 1.5". The 2x4s are doubled over each pillar and a 4x4 is sandwiched in between to use as a leveler. The doubled 2x4s are set on 12" centers.
None of the deck is touching the ground. The whole deck rides on the 4x4s, which are setting on roofing shingles so they do not contact the ground.
Each of the 2x4s are fastened to the 4x4s with 6 to 8 3" deck screws.
My question is (finally). Are the deck screws enough to support the deck? Or do I need to put a bolt through each 2x4/4x4?
Thanks!
rsmith0399 is offline   Reply With Quote
Old 01-10-2012, 05:31 PM   #2
since the deck is at ground level the screws would be enough, however, as a precaution you may want to remove the screws on every other 4x4 and replace with either lag bolts or bolts that go all the way thru.
rodu is offline   Reply With Quote
Old 01-10-2012, 08:35 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
personally i would just use galvanized gun spikes.. 100 x faster and much much cheaper than 3" screws.. its sitting at grade. it cant go anywhere
woodworkbykirk is offline   Reply With Quote
Old 01-10-2012, 08:55 PM   #4
Disabled wood vet
titanoman's Avatar
Um...I guess.
I don't believe I've ever seen anything like that before.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 01-10-2012, 09:16 PM   #5
Retired carpenter
Just the screws should do it.
You could have used continuous 4x4s and saved yourself from all those 2x4s, but hey.
abracaboom is offline   Reply With Quote
Old 01-10-2012, 10:08 PM   #6
Moderator
kwikfishron's Avatar
There's a waste of materials and labor.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is offline   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
AndyGump (01-11-2012)
Old 01-10-2012, 10:22 PM   #7
Disabled wood vet
titanoman's Avatar
I'm serious. I've been around the block a few times and have never seen anything like that.
I can't help it, I keep going back and studying it more. What about that 45 action?
Old 01-11-2012, 01:30 AM   #8
Retired carpenter
There's more to a job than time and materials. I'm sure that Mr. Smith derived great pleasure from building it, and if he 45d a corner, there must be a good reason for that (fancy board design).
I'll bet those 2x4s are dead level along the whole plane!
Old 01-11-2012, 06:59 AM   #9
Disabled wood vet
titanoman's Avatar
I'll bet not. You can see the waves in it.
Old 01-11-2012, 01:53 PM   #10
robertcdf's Avatar
Ummm... I'm also at a loss for words... Sometimes a deck is not the answer and a paver stone or concrete patio is the answer.
robertcdf is offline   Reply With Quote
built a new cedar deck used galvanized instead of screws should i replace all nails? abbyaudi Carpentry 8 04-19-2010 11:57 AM
Ground level deck Daddyshammer Building & Construction 56 09-13-2009 08:58 PM
Composite vs wood deck screws cranedk Building & Construction 2 08-04-2009 01:07 AM
Deck footers not 100% level? ssgumby Building & Construction 1 05-11-2005 08:32 PM
DECK decking nails vs screws ... christian15213 Building & Construction 8 05-02-2005 08:51 PM
