Grind Top Of Concrete Pier - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-25-2010, 03:52 PM   #1
Grind top of concrete pier
I am building a low deck, partially over an existing patio. I poured several 8" concrete piers and a few of them are off, maybe 1/2" or so. Is there a way to grind off the top of the pier?
Thanks!
Ron
rsmith0399 is offline   Reply With Quote
Old 04-25-2010, 03:57 PM   #2
Civil Engineer
Rewards Points: 4,954
Sure you could grind the piers with an angle grinder, but why bother? I assume you are using 4x4 or 6x6 wooden posts on top of the pier to support the deck, simply adjust the length of the posts to make the deck level.
Daniel Holzman is online now   Reply With Quote
Old 04-25-2010, 05:01 PM   #3
DIY staff
Rewards Points: 7,174
Daniel--sounds like he wants to use the pier to support a girder.
RSmith--Buy a cheap 4 1/2 inch angle grinder--I paid $16.00 for the last one I bought.
A diamond cutting blade is less than $10-
A Skill saw could also be used with a diamond blade--$15.00 to $40.00 Depending on quality.
To trim down a couple of piers that are to high---I'd think a cheap blade will get the job done.
---Mike--
Old 04-25-2010, 05:08 PM   #4
kwikfishron's Avatar
Rewards Points: 1,018
How about knotch the wood?
kwikfishron is online now   Reply With Quote
Old 04-25-2010, 06:18 PM   #5
Yes, why knot?
Sawdust is harmless, concrete dust not so.
Old 04-25-2010, 06:36 PM   #6
Concrete & Masonry
Rewards Points: 650
Shim up the low ones 1/2" & wait for all the tubes to sink.........
In all seriousness, oh-mike has the best answer IMO. Grind for a while, or set a diamind sawblade down about 3/4", sawing reliefs every 1/2" or so, & then chisel all the weakened pieces off from the side.
jomama45 is online now   Reply With Quote
Old 04-25-2010, 08:56 PM   #7
Registered User
Rewards Points: 526
Constant garden hose mist with a wet/dry vacuum, and as stated. Wear goggles and mask . Not snorkel.
Be safe, Gary
Old 04-25-2010, 10:18 PM   #8
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
Be safe, Gary
and be sure you use GFCI protection for the circuit.
The Following User Says Thank You to nap For This Useful Post:
oh'mike (04-26-2010)
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 06:25 PM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 04:53 PM
Concrete or Steel Pier Foundations? TheBeetleGuy Building & Construction 7 09-21-2009 02:57 PM
grind concrete pad? calvinspal Building & Construction 3 08-02-2008 04:00 PM
concrete pier cibula11 Building & Construction 5 06-16-2007 09:11 AM
