Green Guard XPS Foam Fanfold - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-13-2011, 09:29 PM   #1
Green Guard XPS Foam fanfold
Can a house wrap like Tyvek be used over Green Guard XPS Foam fanfold siding underlayment?
fabio is offline   Reply With Quote
Old 02-13-2011, 10:49 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
yes,but it's a good idea to bring all the penetration drainage to over the tyvek and not behind the foam
Tom Struble is offline   Reply With Quote
Old 02-14-2011, 06:24 PM   #3
Well we are thinking about using just the xps tape all the seams with 3" tape, what do you think?
Old 02-14-2011, 06:50 PM   #4
yes i would tape the seams,is this over existing siding?
But see there is more to it than that,what you want to try to accomplish is bringing any water from any window or other penetrations to the outside of the foam where it can drain away harmlessly
you can use a combination of tyvek,foam and tape to achive a pretty decent drainage plane
Green Guard XPS Foam fanfold-1026100910.jpg   Green Guard XPS Foam fanfold-1027101245.jpg
Old 02-14-2011, 08:18 PM   #5
This is what my siding contractor wants to do is install on Bildrite seal all the seams and flash around windows, then nail seamless steel siding, will this work ? I would like to use a building wrap,they claim this is better.What to do? ThankYou.
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Replace Flange in basement with Foam? mattoxda Plumbing 1 10-10-2010 04:05 PM
Hybrid wall insulation consisting of 2" rigid foam + 2x4 fiberglass batts? TitaniumVT Building & Construction 15 09-14-2010 02:50 AM
Green is the New Black aaron.klimchuk Green Home Improvement 36 02-17-2009 09:07 AM
closed cell vs open cell foam insulation amonalisa Building & Construction 1 11-06-2008 09:39 PM
