Green Fiber In Walls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-27-2011, 09:52 PM   #1
Green Fiber in walls
I would like to put Green Fiber in an 8x12 shed/cabin that I am building. I know that I get the blower for 24 hours from Lowes or Home Depot. Typically when I read about putting Green Fiber in walls it is for retrofitting walls and it is put in through holes cut in the walls. What's the best way to do this when building new 2x4 framed walls? It would be nice to do this without having to cut and plug holes. Someone told me that the blower that you get from the box stores isn't strong enough for insulating the walls but it doesn't seem like you would need a strong blower because your just gravity filling them. Thanks for any advice.
lukabrazi is offline   Reply With Quote
Old 02-27-2011, 11:54 PM   #2
Rewards Points: 1,092
Suggestion: go over to greenbuildingadvisor.com and search for dense packing cellulose (if that is what GF is. Pretty much the same deal if it is 'glass). It may be best for you to dense pack into a slot in the wall, and fill it in afterwards. Robert Riversong has been dense packing cellulose for decades and has posted a lot about it on the GBA site. Builditsolar.com also has good info, though mostly for double-stud walls. Force 1 and Force 3 blowers are tough enough. Our Ho De Po rents them. You'll want to shoot for 3.5 lbs/cf. Also, in a place that small, it may be about a wash stuffing cotton or wool batts into the wall, and air sealing well (which is standard normal, regardless of insulation).
Painting over green interior walls - hard to cover marliz Painting 14 03-26-2011 07:49 AM
Insulation of interior walls around fire place ODD Calmeier Building & Construction 5 01-31-2010 05:59 PM
Insulate/air seal shared walls in townhome? RebornRenov Building & Construction 4 01-07-2010 09:50 AM
Paint options for basement walls and floors 68tele Painting 8 10-28-2009 06:09 PM
Some walls rattle in my house if hit with something, I will explain inside posting zincmann Building & Construction 4 11-10-2008 03:05 PM
