-   -   green board or tile for ceiling in a low standing shower? (http://www.diychatroom.com/f19/green-board-tile-ceiling-low-standing-shower-108366/)
vote4Pedro 06-21-2011 03:27 PM
I'm building a small standing shower about 36x32 in the basement. it'll be a pretty small space and the ceiling is about 7ft tall. I'm currently in the process of putting up durarock for tiling within the stall and was wondering if anyone have recommendations as to if i should tile the ceiling as well? This would be just for the ceiling space above the shower stall because a lot of moisture will get kicked up.
cost aside, i'm generally concerned with the weight of the tiles/durarock over someone's head as opposed to a green board.
tx
Ron6519 06-21-2011 05:12 PM
If you install it correctly, you will not have a problem.
vote4Pedro 06-21-2011 05:26 PM
do you mean the durarock or green board install? i've done durarock and tile before for side walls, it's pretty sturdy. just never installed it on the ceiling and wondering if it's a common practice for low ceilings due to moisture.
Ron6519 06-21-2011 05:31 PM
I'd use cement board in a wet area. The tiled ceiling would make sense to me in a confined area, but I've tiled many bath ceilings that were standard height.
I'd make sure the vent fan was sized correctly and there was no ceiling drop down(header assembly) to trap moisture in the shower area.
Bud Cline 06-21-2011 06:37 PM
I've been installing ceramic tile and tilebacker board on shower ceilings for decades. Never had a problem doing it. Last week I installed 20" porcelain tile on a 7'X9' shower ceiling.
Here's my little suggestions FWIW.
#1. Use Denshield and not cement board.
#2. Denshield can be glued in addition to screwing it, cement board can't effectively be glued.
#3. Install the proper hi-lo-thread screws every six inches.
#4. The main thing is to install the ceiling rafters/joists on 12" centers.:)
