Green Board/ Good Or No? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-04-2006, 01:54 PM   #1
General Contractor
Green board/ good or no?
What is the deal with using green board for a bathroom un-tiled walls & Ceilings. Contractors I have notices are going back to just using regular old drywall. My guy says drywall prime and 2 coats of paint is all you need. I know the reason isn't he's cheap, but it a moisture control issue. Does anybody know, because I would like to know.
Thanks...
fqp25 is offline   Reply With Quote
Old 09-04-2006, 04:08 PM   #2
Master Craftsman
Big Dave's Avatar
It's supposed to be mold resistant and water resistant. It is not water proof or mold proof. Your best line of defense is what you said, prime and 2 coats. An eggshell or higher sheen is better.
Dave.
Do one thing at a time, do it well, then move on.
www.bigdaveswoodworks.com
Big Dave is offline   Reply With Quote
Old 09-05-2006, 11:37 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Look Up XP-board at the NATIONAL GYPSUM website, if you want a full description of MR and Mold resistance....
We use it from time to time (For Over-kill) the only situation where I think that it was a 'must', was in an room that had a steam room off of it, in a basement.
Do like Like Big Dave said...should be fine.
- Build Well -
Old 09-05-2006, 01:52 PM   #4
They're all fixer-uppers
J187's Avatar
Rewards Points: 508
Atlantic, I'm still not seeing that purple board showing up in the big box stores around here. The HDs and Lowes' near me all don't have it. Have you noticed it out in your area, we really aren't that far apart.
FQP - I used greenboard in my bathroom on the untiled walls. I'm really not sure how much difference it makes, I just think it gave me a small sense of security - probably false but oh well. I used Sherwin WIlliams "bath Paint" and "pro block" primer. It came out great. I have one of those high pressure shower heads without a restrictor washer - Still, moisture hasn't been a problem at all.
J187 is offline   Reply With Quote
Old 09-05-2006, 08:11 PM   #5
Yeah, that's funny, I was in HD last week and one of the Contractor counter people was telling me about a deal they had on MR board. I told them about the XP Board, and she had never heard of it.
We buy it from a Drywall supplier in Tyngsborough, MA. They have almost every kind of Sheetrock you can imagine.
- Build Well -
Old 09-06-2006, 08:33 AM   #6
J187's Avatar
Rewards Points: 508
Does said supplier sell to everyone or contractors only? Often, I can't even find different sized Drywall at the local box stores. In case a need arises again soon, Tyngsboro is only 35 minutes or so away.
Old 09-06-2006, 10:00 AM   #7
Darylh's Avatar
Thanks...
I look at it this way, Evert little bit helps.
Darylh is offline   Reply With Quote
Old 09-06-2006, 07:37 PM   #8
We have been buying Our Drywall supplies from them for over 20 years.
They are really great people. They sell to anyone (Not just Contractors) and are very knowledgable and helpful.
- Build Well -
Installing backerboard - replace particle board? salvop Flooring 10 04-29-2011 11:32 PM
Hardie Board Siding and Wind gordo409 Building & Construction 2 07-10-2007 07:00 AM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
Ruud a/c control board replacement ? kourso HVAC 1 07-20-2006 10:33 PM
particle board / hardibacker fish3211 Flooring 4 08-10-2005 09:32 PM
