Old 09-29-2010, 02:03 PM   #1
Great Stuff and 6 mil poly vapour barrier
Does anyone know if Great Stuff can come in permanent contact with a 6 mil poly vapour barrier and not eat away at it or damage it? I called Dow and they said "it shouldn't" but I typically don't like/trust "it shouldn't" as an answer.
maljeff is offline   Reply With Quote
Old 09-30-2010, 02:19 AM   #2
I've gotten GS on poly several times, as spill-over, and it did not do anything but dry. Some of that sat around for years before I got back to it and cut the poly off; the GS was just sitting there. So, I guess my answer is "It shouldn't".
Old 09-30-2010, 09:27 AM   #3
I've had the same results
littlecleo is offline   Reply With Quote
Old 09-30-2010, 11:59 AM   #4
Thanks for the info, much appreciated.
I have one more question I'm hoping you can help me with. I have some polystyrene insulation glued to my interior basement walls. I noticed that a few of the panels have a few small holes in them - not sure what from as I'm not the original owner. Can I fill those holes with GS?
thanks
Old 09-30-2010, 01:26 PM   #5
do a test zap somewhere to see if you have any dissolving issues. if not, fill 'em in. j
metal left in hardwood floor sealer deetu Flooring 26 06-16-2012 08:29 AM
Great Stuff Foam Between Walls chadwilliam1 General Discussion 2 07-04-2010 07:37 PM
Great stuff around boxes? jamiedolan Electrical 6 12-15-2008 04:07 PM
Great Stuff question amakarevic Building & Construction 14 01-02-2008 11:28 AM
foam like Great Stuff that is waterproof amakarevic Building & Construction 1 12-30-2007 09:52 PM
