Gravel Under Slab? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-20-2009, 01:52 AM   #1
gravel under slab?
We are building a 22x19 addition crawl space foundation and like to know if gravel necessary under the concrete slab besides vapor barrier?
Thanks.
ptcamaro is offline   Reply With Quote
Old 08-20-2009, 05:50 AM   #2
Yes!! It allows drainage somewhere to flow, it allows some movement from weather changes, etc. And there should a a perimeter drainage system as part of the design.
Old 08-20-2009, 07:44 AM   #3
Concrete & Masonry
Rewards Points: 548
Generally, 4 inches of #1 washed stone (#57 or the like) is required by code to aid in under-slab drainage.
jomama45 is offline   Reply With Quote
Old 08-20-2009, 08:15 AM   #4
Rewards Points: 4,578
if its mine, crush'd stone,,, according to specs over/down here in sc/ga, compact'd sand-clay - UNLESS a soils test sez different i'd still use vapor barrier over a sand cap, too !
Cement slab touches buildings cbuisman Building & Construction 2 06-09-2009 10:24 PM
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 12:17 PM
Pouring a concrete slab - Do I need a 4" gravel base? tokuzumi Building & Construction 2 11-27-2007 07:40 PM
Filling hole in carport (concrete slab) chaddihimself Building & Construction 2 08-10-2007 12:50 PM
