Gravel Type For Post Hole Drainage - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-04-2012, 11:05 AM   #1
Gravel Type for Post Hole Drainage
I understand that it is a good idea to put gravel in the bottom of a post hole to promote draining. Is there a preferred gravel to use for this application? Is Pea gravel better than limestone?
Thanks in advance for your reply.
napergman is offline   Reply With Quote
Old 02-04-2012, 11:14 AM   #2
Civil Engineer
Rewards Points: 4,792
The term gravel (in engineering classification) means the fraction of soil greater than approximately 1/8 inch in diameter. Pea gravel is a colloquial term referring to gravel which is typically greater than 1/2 inch in diameter. Gravel may be made of essentially any kind of rock, including common types such as limestone, granite, or sandstone. For your purposes, it makes no difference what kind of rock the gravel is made of. Your local material supplier will have a range of gravel size from 1/8 inch up to at least 3/4 inch, it may be called crushed stone, it may have a local name, as long as it contains only a small amount of fine material (less than 10 percent by weight) it will work well for drainage.
Daniel Holzman is online now   Reply With Quote
The Following User Says Thank You to Daniel Holzman For This Useful Post:
napergman (02-04-2012)
Old 02-04-2012, 11:27 AM   #3
Fantastic explanation. Thanks. I can go to a local quarry and get small amounts (under 1000 lbs) of any limestone I want for free. Just saved me some cash.
30 Year Old Plumbing System - Gravel Pit / No Permit or More Expensive Complete? RockSplat Plumbing 3 07-05-2010 03:26 PM
Cutting out a hole on a stainless steel sink...pics Goldglv General DIY Discussions 14 02-28-2010 10:04 PM
Broken caliper bolt chrissyb Automotive Repairs 12 12-28-2009 03:18 PM
what type drainage pipe to use on a gravel way markstrt339 Building & Construction 1 11-30-2008 04:30 PM
Drainage issue and need suggestion on type of grass golfer2b Landscaping & Lawn Care 9 03-24-2008 07:38 PM
