Gravel Or Sand - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-10-2010, 09:45 AM   #1
Gravel Or Sand
What is the difference between useing gravel or sand as a bed over compacted soil in order to lay a concrete slab? I hear of both.
And, I have always heard that wet sand is 100% compacted. But, in other projects, when watering down a layer of sand and walking on it, your foot sinks about and inch into it. 100% compaction???
Paul
tttmex is offline   Reply With Quote
Old 07-10-2010, 09:55 AM   #2
General Contractor
For a patio, if the earth is undisturbed and firm, and at the correct grade, go straight over it with your vapor barrier and concrete. If you need to level, compact or bring up the grade, use 3/4 minus rock, compact that, then the VB and concrete.
My ignorant youth allows me to posit that sand is generally for dinosaurs. (And never put it between the VB and the concrete, a rumored crazy practice specific to the lower West Coast).
Have fun,
Rory
RDG Read Development LLC
Portland, OR
Rory Read is offline   Reply With Quote
Old 07-10-2010, 10:45 AM   #3
Rewards Points: 392
Paul
Paul, when you walk over sand, your foot is displacing the sand. But, if you lay down, say a piece of a foot square of plywood and stepped on it, it wouldn't displace it.
rustyjames is offline   Reply With Quote
Old 07-10-2010, 10:49 AM   #4
Rewards Points: 392
Have fun,
Rory,
What would be the purpose of the vapor barrier under a patio, (unless you were going to convert to conditioned space later)?
Old 07-10-2010, 10:57 AM   #5
Rewards Points: 1,016
I was tought to use sand - one reason was to keep rocks or other from puncturing the vapor barrier.
Old 07-10-2010, 02:05 PM   #6
General Contractor
good point
That's a good point re no need for a vb under an exterior slab. I wonder if the slab is indoors or out?
Rory
Portland, OR
Old 07-10-2010, 02:08 PM   #7
Concrete & Masonry
Rewards Points: 548
I would recommend compacted gravel vs. sand anyday. The sand get's tore up too easily from working in the slab.
And I'm curious as to the benefit's of a vapor barrier under exterior flatwork as well?????
jomama45 is online now   Reply With Quote
Old 07-10-2010, 03:39 PM   #8
Registered User
Rewards Points: 5,482
11 year old report: ftp://imgs.ebuild.com/woc/C99C023.pdf
Be safe, Gary
Old 07-10-2010, 03:43 PM   #9
concretemasonry's Avatar
Rewards Points: 2,594
The benefit of a real vapor barrier (10 mil) is if the area was ever enclosed (addition, 3 season room, shed, etc.) it is already there.
It also prevents capillary moisture from getting into the slab.
I would use a compacted gravel base with a thin sand cushion and then a tough VB.
If you ever have a moisture problem with a slab, you might wish you spent a few pennies for a good VB instead of $$s to tear out, removal and replacement.
Cement finishers can be lazy and do whatever is necessary to make their jobs easier and faster - the same applies to wire and reinforcement even though thye do not make money on the extra materials. - Unless you are shopper nad they are better at selling minimal services. A good buyer is also a good seller.
Dick
concretemasonry is online now   Reply With Quote
Old 07-11-2010, 03:24 PM   #10
Compacted Gravel?
How do you compact gravel? Does the tamping method push the gravel into the already compacted subdirt??
Old 07-11-2010, 04:29 PM   #11
The gravel (base material) has the right amout of the properly sized particles and enough (not to much fines) to help it compact and bridge over poorer soils. The worse the subgrade or the higher the load, the thicker the base should be. Compacted base should be smooth and have to loose particles coming of if you walk on it.
Base material is common everywhere and is used under concrete and asphalt surfaces, but different place have some local terms that are used.
You say you have compacted "soil" but if it is not good "soil" it could be meaningless.
Dick
Old 07-11-2010, 04:59 PM   #12
Registered User
I hope no one turns there patio into an addition, screen room, etc. without thickening the perimeter edges for the wall and roof added weight.... then a v.b. would be required, if heated space. For a screen room conversion, you would need footings under the slab for the roof posts carrying the roof structure. Wouldn't the v.b. under a patio slab keep the water from draining, if the slab was poured on the leveled sub-grade for a patio? And possibly freeze easier if the slab is covered with snow that melts into the porous concrete slab during the day- pooling there to freeze at night? I would think you wouldn't want a v.b., unless knowing it would be a heated conversion by you, soon. Then I would suggest insulating the perimeter with 2" x 2' deep rigid foam board to counter heat lose. That seems a lot of extra time, energy and money--- adding thickened (12" x 12") edges, perimeter insulation, a heavy gauge v.b., post footings, then raised perimeter 6" wall (to install siding per code), which the B.D may not accept later as the patio probably wasn't inspected when poured. (A big shock when you go for the addition's permit).
I agree with the fines and gravel, though.
Be safe, Gary
Need Help - Failed Patio in Sand Install lews Landscaping & Lawn Care 5 04-19-2010 06:34 AM
how to light sand texture ceiling mtom01 Painting 4 03-13-2010 12:11 AM
Best Way to Establish Plantings Over Sand flyboy Landscaping & Lawn Care 4 04-07-2009 09:38 AM
Sand vs. Pea Gravel? Shpigford Landscaping & Lawn Care 3 03-18-2009 02:33 PM
painting sand over sand heather Painting 1 04-03-2007 10:35 AM
