Gravel Driveway - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-08-2007, 07:28 PM   #1
Gravel Driveway
Hi
I'm new here.
I need your help.
I want to add a gravel driveway to widen my existing driveway.
Where I live you can not park on grass or dirt. You don't need a permit
for gravel.
I need to know how deep
What the base needs to be and how thick then how deep the
needs to be
I would deeply appreciate any help I can get.
Wild Cadillac
WildCadillac is offline   Reply With Quote
Old 05-09-2007, 09:41 PM   #2
Remove all vegetation. Then out down 3-4 inches of 3/4" (or 1 1/2") road base. Then top it with whatever you like. Bigger rocks will last longer as they are more difficult to squish into the mud. The road base might work just fine alone. I think using road base is a good idea because it is designed to compact to together to form a sturdy layer. The different sizes of aggregates form a matrix when compacted that is much sturdier than just plane gravel.
Good luck!
ColoradoBuilder is offline   Reply With Quote
Old 05-10-2007, 11:53 AM   #3
Do you need a permit for asphalt in your area. I was just wondering because I had some put in and was told I did not need a permit. Anyway for my other driveway I used 3/4 crushed gravel. I killed the vegitation then the driver came set his chains on the truck and he dumped out the gravel in a nice even ( about 4 inch) layer. Then I got lucky because they were putting a road in by my house and I had those guys come over with a vibrating roller ( this thing was huge it shook my whole house). I have had the road for 10 years now and I have not had to do a thing to it.
warnerww is offline   Reply With Quote
leaking tar and gravel roof meleis Roofing/Siding 9 01-05-2008 10:27 PM
3/4" Gravel on Sloped Driveway not locking - help? WynsWrld98 Landscaping & Lawn Care 7 10-17-2007 11:02 AM
gravel driveway darren Landscaping & Lawn Care 4 05-15-2007 05:24 PM
