Gravel Drainage - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-02-2012, 11:35 AM   #1
gravel drainage
Will gravel around the foundation of my home help with drainage? How should it be done?
Where one has low windows just above the ground.. even though there is proper drainage in place off the roof.
How_to_do_it is offline   Reply With Quote
Old 06-02-2012, 03:13 PM   #2
Remodeling Contractor
you need drain pipe which gets covered by gravel so the holes do not get clogged. Gravel by itself will do nothing to help with drainage.
Old 06-02-2012, 09:08 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,708
Ayuh,.... The roof is drained, but is there pitch Away from the low windows,..??
Gravel Type for Post Hole Drainage napergman Building & Construction 2 02-04-2012 11:27 AM
Will gravel around house help drainage? evolve Landscaping & Lawn Care 9 05-30-2011 02:23 PM
How to Keep Gravel from Washing Out of Drainage Ditch Jaylyn Landscaping & Lawn Care 4 01-27-2011 06:17 PM
gravel for drainage dcberg Building & Construction 6 07-19-2010 12:35 PM
what type drainage pipe to use on a gravel way markstrt339 Building & Construction 1 11-30-2008 04:30 PM
