Grate Drain At Bottom Of Steps - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-02-2011, 01:10 PM   #1
Grate Drain at Bottom of Steps
I want to put the grate drain at the bottom of the steps where the blue square is located. The grate drain is 5 inches deep. My footer is 6 inches deep. I do not want to go under my footer. Can I knotch out a part of the footer (yellow circle) to connect to the drain tile? Or will that cause a structural issue. The reason is water runs down the step during heavy rainfall. I am using 4 inch perforated pvc.
sloojoe is offline   Reply With Quote
What's Needed for Drain Tile / French Drain samsmith Building & Construction 2 08-24-2010 11:20 AM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
adding new sink / faucet / drain assembly... and I'm clueless :-( diy'er on LI Plumbing 4 11-13-2009 05:36 PM
How to outline the 1 1/2" PVC drain froddan Plumbing 6 07-24-2007 03:15 AM
