Old 09-21-2011, 08:56 PM   #1
Granite Seams - Is This Bad?
I'm not trying to sound picky, but is this a bad seam?
csutton11 is offline   Reply With Quote
Old 09-21-2011, 09:06 PM   #2
Pictures are a little far away, but the epoxy filler looks a little light colored for the granite.
Ron
B. Franklin 1759
Old 09-21-2011, 09:19 PM   #3
Thanks Ron! I've attached one a little closer/different angle.
Old 09-21-2011, 09:49 PM   #4
With that varied stone color, the epoxy mix should have been better. The seams I've seen done, they mix up colors close to the stone and fill the gap. This can be fixed by scoring the seam down 1/4" and remixing a better color combo.
Call them back and point out the issue.
Ron
B. Franklin 1759
Old 09-21-2011, 11:51 PM   #5
Too Old
It looks like grey when it should be black. How is the rest of the slab? It is an easy fix if it is only the color.
"Yeah, it's a nice garage, but you have to keep it heated at all times so it doesn't mess up your roof line."
havalife is offline   Reply With Quote
Old 09-22-2011, 12:41 AM   #6
Yeah the color is off. I would call them back to redo it. Are those seems near a sink? I would never have cut it like that if it is but thats just me.
epson is offline   Reply With Quote
Old 09-22-2011, 07:55 AM   #7
its not a great seam but w/large variegated granites, they never are yes, the color could've been a bit darker but its not a deal-breaker to me,,, i'd also guess ( since that granite looks relatively inexpensive [ not discussing what you paid for the job ] ), the fabricator/contractor might have been selected based on costs all others qualifications considered,,, so here's the real issue - does your guy have the talent/expertise to make that seam what you 'see ' in your head OR not ? good luck !
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders !
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help
itsreallyconc is offline   Reply With Quote
Old 09-22-2011, 08:48 AM   #8
How easy is it to break apart that seam without breaking anything? I would think that epoxy is pretty strong, no?
bob22 is offline   Reply With Quote
Old 09-22-2011, 08:56 AM   #9
surprisingly enough, its fairly easy to break that seam however its impossible to do that without breaking anything/everything
Old 09-22-2011, 02:28 PM   #10
You do not "break" the seam, you score(cut through to a depth of 1/4") the top 1/4" and fill it in with the correct color.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
Bud Cline (09-23-2011)
Old 09-22-2011, 03:36 PM   #11
Ron,
Thanks, that makes more sense than what I envisioned.
Old 09-23-2011, 12:28 AM   #12
firehawkmph's Avatar
IRC,
Please change your font to a normal one and a little bit bigger. Very hard to read. Thanks,
Mike Hawkins
firehawkmph is offline   Reply With Quote
The Following User Says Thank You to firehawkmph For This Useful Post:
Old 09-23-2011, 11:29 AM   #13
Actually that's pretty typical of a lot of granite installs. Most places can do quality fabrication but the install crew is just............. guys that can lug it in. The truly good installers can put the rest to shame and would never have left that looking the way it does, but like anything else, "truly good" is a small % of the overall.
Is it even epoxy-filled? Hard to tell from the pic but it almost looks like someone just leveled it out w/ silicone (again, it happens frequently).
ThatDaveGuy is offline   Reply With Quote
Is this a lousy granite installation? timbo59 Kitchen & Bath Remodeling 70 05-16-2013 11:08 PM
Repairing Cracked Granite Seams wesley8808 Building & Construction 0 01-07-2010 11:01 AM
Stonemark & Silestone Countertops......??? DepotDweller Remodeling 9 06-25-2009 12:44 PM
Granite Hearth/Saltillo tile transtion help SeminoleMike Flooring 2 02-08-2009 12:49 PM
Granite not installed correctly???? debsc Kitchen & Bath Remodeling 7 02-01-2009 09:58 AM
