Granite Overang Supports YES/ NO / Where - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-07-2011, 04:14 PM   #1
Hello everyone,
I have 3cm granite installed over base cabinets with a 10.5 inch overhang. The total width of the granite is 37 inches with a run of 78 inches.
Question 1. Do I need support? I have seen several sites that say anything under 12 inches, support is not needed.
2. Since the granite is already down how can I hide them in the cabinet? I have three L Brackets that the store recomended but since they are being fastened to the thin cabinet wall what is the best solution?
Thanks for the knowledge
Here is a photo if that helps
slalomskie is offline   Reply With Quote
Old 11-08-2011, 12:32 AM   #2
iminaquagmire's Avatar
Rewards Points: 338
You don't have a big overhang but IMO anything over 8" should have some support. You can either use the L brackets or some decorative corbels. The strength of the back doesn't really come into play since if your granite is going to break, its likely going to do so with less force than it would take to break the back of the cabinet. If you don't want to see the support, you could get some 1" square steel tube or some 3/8 x 1 1/12" steel plate and epoxy it to the underside of the cabinet. This would require some small notches in the back of the cabinet. I've seen the steel used after the fact but its better if the fabricator could have epoxied it INTO the granite.
iminaquagmire is offline   Reply With Quote
Is this a lousy granite installation? timbo59 Kitchen & Bath Remodeling 70 05-16-2013 11:08 PM
Do you have a Wood/Pellet Stove Insert with a Raised GRANITE Hearth? gmoom Remodeling 1 01-24-2011 05:54 PM
Stonemark & Silestone Countertops......??? DepotDweller Remodeling 9 06-25-2009 12:44 PM
Granite Hearth/Saltillo tile transtion help SeminoleMike Flooring 2 02-08-2009 12:49 PM
Granite not installed correctly???? debsc Kitchen & Bath Remodeling 7 02-01-2009 09:58 AM
