Granite Kitchen Countertops Replacing Tile/mortar Countertops - What To Remove? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-10-2009, 06:37 PM   #16
Rewards Points: 348
If the installer will prep the cabinets it might be well worth the extra $$ so they can not blame any problems on the prep work.
RegeSullivan is offline   Reply With Quote
Old 06-10-2009, 07:06 PM   #17
Uhh...8 month old thread ?????
Old 06-10-2009, 07:32 PM   #18
Old School
cabinetman's Avatar
Yep, you're right. But, the essence of the thread may be of interest to some current members. Both granite and marble fare better when substrated with plywood. If the cabinet height is 34 1/2" (what is needed for undercounter appliances), a total thickness above that should be 1 1/2". An add on buildup for a bullnose, or some other profile gets epoxied on and ground and polished. The back edge of the buildup hides the front edge of the plywood. This is a very common practice.
The plywood can be screwed to the cabinets and the granite is set in adhesive caulk, like Polyseamseal.
cabinetman is offline   Reply With Quote
Stonemark & Silestone Countertops......??? DepotDweller Remodeling 9 06-25-2009 11:44 AM
Granite Countertops and Restaining kennykenny Remodeling 64 05-01-2009 11:15 PM
Replacing Kitchen Countertops diyDiva40 Remodeling 2 09-25-2008 08:30 PM
Using granite & laminate for kitchen Jetboy55 Remodeling 5 08-10-2008 09:56 AM
Remove Granite Counter tjsmadison Building & Construction 5 11-18-2007 01:13 PM
