Grading An Existing Deck - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-16-2013, 03:32 PM   #1
Rewards Points: 119
Grading an existing deck
Hi,
I have an existing second story deck over a concrete patio, which we want to waterproof and therefore need to add a grade to the deck surface for water run-off. The deck is approx 40x10.
The current thinking is that I can use screwjacks to support the deck while I cut approx 2" out of the support posts and then lower and reattach the support beam to the posts. I am worried about the effect this will have on the ledger board where the joists are attached, i.e. will the residual stresses have an effect?
Also, it doesn't look like the ledger board is attached using lag bolts or the like. How else would they have attached this back in 1998? Was it code then to use lag bolts or similar?
Chris
spiragui is offline   Reply With Quote
Old 02-16-2013, 03:38 PM   #2
Rewards Points: 14,026
Picture did not come out.
And your right to be worryed.
Old 02-16-2013, 03:41 PM   #3
http://www.bing.com/videos/search?q=...stem&FORM=VDRE
Old 02-16-2013, 03:41 PM   #4
Rewards Points: 119
Wierd about the picture. It shows up in Chrome, but not IE. If you click on it in IE though it displays OK...
Old 02-16-2013, 03:43 PM   #5
Rewards Points: 119
Joe,
I looked at the undersurface drainage systems, but we get a lot of tree debris around here and I think it would be a maintenance nightmare. Plus we want to install potlights etc underneath the deck. Also there is a lot of blocking (for the non-square corners etc), sistered joists etc that makes the underdeck systems very difficult to install.
Chris
Old 02-16-2013, 04:29 PM   #6
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,648
Originally Posted by spiragui View Post
Hi,
Chris
Ayuh,.... 2 inches in 10 feet is too much,.... It'll be noticeable walkin' it...
An Inch is plenty...
Bondo is online now   Reply With Quote
Old 02-18-2013, 05:47 PM   #7
Rewards Points: 119
Thanks Guys,
I think I will aim for about 3/16 per foot grade. Minimum for the material is 1/8, but they recommend 3/16 to 1/4.
A question regarding attaching the ledger board to the house:
Currently the deck is prevented from pulling away from the house, or shearing vertically, using the nails that are driven through the joist hangers into the ledger board / rim joist. The ledger board is then attached very securely to the house structure (rim joist) using lag bolts. However this just prevents the ledger board from going anywhere; the joists are still only attached by the nails holding the joist hangers. A chain always fails at its weakest link, so why are the lag bolts necessary (assuming of course that the joist hanger nails penetrate through both the ledger board and the rim joist) ?
I know code is based on sound analysis and experience, so I must be missing something. What am I missing? And fell free to berate me if I am missing something blatantly obvious!
Cheers
Chris
Deck stairs over existing stone retaining wall steps joshg3p0 Building & Construction 16 05-02-2012 11:30 PM
Yankee gutter resurfacing options miamicuse Roofing/Siding 24 01-06-2012 08:20 AM
possible gazebo off my existing deck rollinastang Carpentry 3 05-23-2011 03:52 PM
Install Flashing onto existing deck ledger, stucco home Ameekins Building & Construction 1 09-15-2010 05:51 PM
Extend existing deck dknarnd Building & Construction 1 04-25-2010 08:09 AM
