Originally Posted by hartkem
Ill have to talk to the owner. Only the receptionist was there and even though she was very knowledgeable I want to make sure. One thing I notice is the gable end trusses are framed 16" on center. I will be framing 24" with 2x6 walls. I guess If I have an issue with siding alignment I can just add in a stud on the gable or sister it to the side of another. Don't see how that would hurt anything either other than only every 3rd stud would align with the wall studs. Being double 2x6 top plate I don't see this as an issue.
change your nail patterns when you reach the trusses. studs have different layouts and change in walls compared to the attics sometimes. once you find one they are all 16" from there...
Also, consider adding boxing so that you have overhangs on the building and the trusses sticking out will not matter a bit.
