Old 11-28-2008, 10:20 PM   #1
Good Soundproofing Insulation?
Sorry if this is in the wrong spot. I think its okay though.
I have an interior wall that needs to be soundproofed well because it is a shared wall with neighbors in the condo next door. Does anyone have any suggestions for good soundproofing for an interior wall? Cheap would be best but if not I am open to suggestions.
flipjarg is offline   Reply With Quote
Old 11-29-2008, 09:12 AM   #2
Chagres's Avatar
Back when I was a ceiling mechanic full time, a lot of the contracts we got for schools and churches involved hanging acoustical panels on the walls. Of course, they came in custom sizes from a shop, but you could make them. They were basically rigid foam panels, about 1 1/2" thick, covered with fabric. They had a kind of hook glued to the back and we screwed receiving hooks to the wall. Hang 'em just like a picture. They worked great.
Chagres,
http://www.icanfixupmyhome.com
Chagres is offline   Reply With Quote
Old 11-29-2008, 09:18 AM   #3
What do you consider cheap? What size is the common wall?
jerryh3 is offline   Reply With Quote
Old 11-29-2008, 03:14 PM   #4
I don't know what would be considered cheap. I am open to pretty much any suggestion. However, I don't know if I'd like to use the acoustic panels. The wall is an odd shape. It goes from about 8 1/2 ft. to maybe 12ft high.
There is wood paneling I'd like to put back on the wall after insulating it.
Old 11-29-2008, 04:05 PM   #5
I don't know how involved you want to get, but adding mass to the wall would probably help the most. Another layer of 5/8" drywall with a sound dampening adhesive(such as green glue or quiet glue) would probably be your best solution. You could easily replace the wood paneling once the dyrwall is installed. There's also other systems out there like mass loaded vinyl or walldamp:
http://www.asc-soundproof.com/wd-installation.htm
Try some google searches(sound proofing, sound dampening, ...) as see what's out there.
Old 11-29-2008, 04:50 PM   #6
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Sound proofing information:
http://www.soundproofing101.com/
http://www.glacierbay.com/insulation_ultradb.asp
http://www.constructionresources.com...e/acoustic.asp
http://www.acousticsfirst.com/vinyl.htm
http://www.extremesoundproofing.com/...cs/basics.html
http://www.soundprooffoam.com/
- Build Well -
Old 11-29-2008, 05:40 PM   #7
Thanks. I knew you had the list around somewhere.
Old 12-01-2008, 04:04 PM   #8
Woah, thanks for all the info. I never knew there was glue out there for sound proofing. Adding the sheet rock is not a bad idea. Thanks for the input.
Insulation of interior walls around fire place ODD Calmeier Building & Construction 5 01-31-2010 06:59 PM
Insulation Question skavang13 Building & Construction 3 11-16-2008 06:08 PM
Old home insulation woes nowwhatnapster Building & Construction 15 11-03-2008 12:59 AM
Air cavity required behind spray foam roof insulation BigJimmy Building & Construction 9 06-08-2008 01:45 PM
