Is This Good Building Practice? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-23-2012, 09:59 PM   #1
analogmusicman's Avatar
Rewards Points: 560
is this good building practice?
my house was built in 1979. I've seen some questionable things pertaining to how the house was built but overall it seems that the builder kept to the codes. now,I'm putting in a small bath in the basement and I've run into a strange situation which will require some extra work to run the hot and cold water pipes where they need to go.it seems that the wall of my "utility room" (that's where the bathroom's going) that faces the garage is not a regular wall built with 2x4's but rather it's the foundation wall with "sheetrock" attached right to it. I removed a chunk of the sheetrock and yes it DOES appear to follow some sort of code since between the sheetrock and concrete there's a kind of "barrier" with a shiny,foil side facing the room (I guess to reflect the heat). that concrete wall is not really an outside wall since I think it merely has a lot of dirt behind it and the garage floor is on top of THAT. so,what do you guys think,is this "normal"?
BTW: the room IS pretty narrow so maybe this was done to save 3.5"
tnx,
analogmusicman is offline   Reply With Quote
Old 01-23-2012, 10:34 PM   #2
Registered User
Rewards Points: 5,514
Sounds like he ran short of room for studs/insulation so used some radiant barrier foil sheeting. Zero R-value without a space next to it to reflect the heat......http://www.greenbuildingadvisor.com/...search-problem
Gary
Container homes, what foundations does it need?? shabba1985 Building & Construction 27 03-08-2012 12:48 AM
Old Building problems jake62 Building & Construction 5 08-20-2010 08:32 AM
Where can I find good contractor and building material suppliers? geordge Green Home Improvement 3 03-11-2009 11:11 AM
Where can I find good contractor and building material suppliers? denniis Off Topic 5 03-10-2009 09:27 AM
Building simple table boxer1-2 Carpentry 3 05-16-2005 09:34 PM
