Going To Put Up Sheetrock - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-03-2010, 05:14 PM   #1
Rewards Points: 248
Going to put up sheetrock
Hello all, I am planning to put up drywall in my basement. I took down the old paneling and there is furrings there I intend to re-use. But I need to add additional furring. Can I use regular 2x4 as furrings? Or do i need special wood?
thanks in advance.
jburchill is offline   Reply With Quote
Old 10-03-2010, 05:34 PM   #2
Paul
Furring strips in basement
Special wood not required (may consider blue wood to prevent mold growth), however you should moisture barrier between furrings and the basement wall at least to height of grade level, felt paper would be a suitable choice. You did not say if you are adding insulation, if you are the felt paper will also protect the insulation.
Paul
www.finalsay.ca
finalsay.ca is offline   Reply With Quote
Old 10-03-2010, 05:39 PM   #3
Rewards Points: 248
I do plan on installing insulation as well, the Styrofoam sheet that I'll glue on.
Or is there better insulation than that? There will be about 1 1/2 of room for insulation. I have looked at other fiber glass insulation. But I thought it would lose its rating if I crammed it in such a small space.
thanks
Old 10-03-2010, 07:51 PM   #4
Registered User
Rewards Points: 5,266
Check with your local B.D. for treated or untreated natural resistant to decay wood against the concrete. They may require it for bottom plate only. Use a sill sealer rather than felt paper for a thermal and capillary break from the concrete wall and concrete floor. Just paper and glass fiber insulation is asking for trouble.
http://www.buildingscience.com/docum...ent-insulation
Gary
insulation types i can use between current and new sheetrock on ceiling philbee62 Remodeling 4 08-05-2010 08:12 PM
Sheetrock put on w/o removing door trim Carla33 Carpentry 13 12-26-2009 02:32 AM
Using nail Gun on sheetrock jwshome Building & Construction 12 09-08-2009 10:16 PM
Mounting a flatscreen TV on a sheetrock wall TanMan Building & Construction 14 02-16-2009 05:26 PM
New medicine cabinet--old plaster and sheetrock help! garyofnyc Remodeling 4 10-31-2008 11:15 PM
