#16 | |
Master General ReEngineer
Going into a PVC pipe to dig out concreteQuote:
Measure, inside, 'n outside, til ya figure out where it's Supposed to daylight... Assemble a length of iron pipe, abit longer than the pvc, slide it to the end, 'n pound on the end stickin' outa the pvc, against whatever's there... The sounds made should help Id, just what material is there.... With somebody Outdoors, the exact spot should be able to be found, by beatin' on the sounding pipe... |
| The Following User Says Thank You to Bondo For This Useful Post: | Okstout4 (06-04-2012) |
#17 |
AHH, SPANS!!!
the ends of the vent pipes must have fallen short of the exterior wall,the plumber cut them off at the concrete form with them later needing to be extended (upward/outward??) and out and to the exterior of the exterior wall. the concrete guys covered them up in the slab, though if the plumber made it to the form with the pipe then the end of the pipe is right near the edge of the concrete. is the slab close to level with the grade of the land outside or is it a really thick slab with the plans to just hook a vent pipe cover onto the pipe where it extends out of the slab? if someone knows the spot for the final vent exit point it would make it much easier to pin point.
| The Following User Says Thank You to hand drive For This Useful Post: | Okstout4 (06-04-2012) |
#18 | |
#19 | |
Yes, I do believe you are correct. I am hoping it's really close to the concrete, so we won't have troubles trying to get thru it. |
#20 | |
so someone on a post mentioned using the PVC as a route for our pipes. Would that really be a possibility?
| Display Modes | |
| High Rise Building methods - US versus Oz - Steel versus Concrete | Jado | Off Topic | 17 | 09-15-2011 09:47 PM |
| Messed up Cast Iron Drain Pipe (Concrete Floor) +Picture | Rugby6 | Plumbing | 8 | 05-11-2011 01:18 AM |
| Is yellow polyethelene or polyphenol gas pipe now the preferred gas conduit? | MarkSilber | Plumbing | 1 | 09-18-2010 01:10 PM |
| Repair of cast iron sewer pipe within concrete | cando | Plumbing | 5 | 04-23-2009 12:10 AM |
| Septic/sewer pipe replacement | Mendocino | Plumbing | 4 | 11-21-2008 06:40 PM |
