Glulam Beams, Nailing, Notching, Boring.... - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-04-2011, 10:59 AM   #1
Rewards Points: 149
Glulam beams, nailing, notching, boring....
Hello and thanks for any response. ..
I have an 8"x21"x25 foot beam spanning the garage ...
I know you can not bore or notch this beam but what about nailing into it to hang stuff, etc...
Is there any rules to follow here or is it a non issue...
Looking to build a soffit to run some h20 lines using 2x4's and 2.5" 16 g nails...
THanks
beachfront71 is offline   Reply With Quote
Old 07-04-2011, 11:08 AM   #2
Framing Contractor
Rewards Points: 78
Your fine.
sixeightten is online now   Reply With Quote
Old 07-04-2011, 11:10 AM   #3
KemoSabe
loneframer's Avatar
I've used many glulams, LVLs, LSLs, PSLs....
I've never had issues installing joist hangers, attaching hardware, etc.
I'd say you're OK.
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
Old 07-05-2011, 12:02 AM   #4
Framer
you are even allowed to drill through PSL beams but there are codes to it..
joeyr is offline   Reply With Quote
hanging weight off of tji beams?? summer76 Building & Construction 2 04-14-2009 03:00 AM
