Gluing Small Pcs Of Sheetrock? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-20-2008, 09:32 AM   #1
Gluing small pcs of sheetrock?
I'm currently framing in a wall in my basement that is going to have around a dozen "cubbies" in it that I"m going to drywall in and finish with the rest of the room. You can see some of them in the following picture...
Do you think I could get away with using some sort of adhesive to hold the walls and floor/"ceilings" of the cubbies in? I'd do the top/bottom first then use the sides to support them. They're only 13.5" deep. I'm thinking that getting a screw-gun or a hammer inside some of the smaller ones is going to be an excercise in futility. I'm thinking corner-bead will help with the fronts too, but the backs won't have that support.
perpetual98 is offline   Reply With Quote
Old 05-20-2008, 10:16 AM   #2
47_47's Avatar
Rewards Points: 58
I'd use a right angle drill and screw the drywall in. How are you going to tape the seams? I'd also be concerned with drywall on the bottom of the cubbie getting damaged or cracking from weight.
47_47 is offline   Reply With Quote
Old 05-20-2008, 10:41 AM   #3
Registered User
Termite's Avatar
I'd make them from white melamine board and insert them into the holes you've made. That way they're properly constructed and will be much more durable in the long run. You can treat the edges with white edge banding or putty and paint.
I think it is a bad idea to use sheetrock. It will not support itself if not secured to solid framing at each seam. No way for you to do that the way you've built the cubbies. You can't secure drywall to other peices of drywall at butt/perpindicular joints.
4x8x3/4" melamine coated particle board will run you just under $30.
Old 05-20-2008, 10:49 AM   #4
3/4" melamine is too thick. Can drywall mud stick to melamine?
Can a DIY build a small in-ground swimming pool? zel General DIY Discussions 14 06-15-2013 09:42 AM
heat/smoke damaged sheetrock treedoc General DIY Discussions 9 02-08-2008 09:00 AM
Number of circuits needed for a small kitchen? All responses welcome! alexz Electrical 5 04-07-2007 10:38 AM
pipe leak & sheetrock damage santogr General DIY Discussions 2 03-04-2007 01:44 PM
Reparing sheetrock abelsu Painting 8 02-23-2007 09:41 AM
