Glass Tile Backsplash - Prep Work Advice Sought - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-25-2011, 10:43 AM   #1
Rewards Points: 79
Question
Glass Tile Backsplash - Prep work advice sought
Standard drywall, recently painted twice, 16" O.C. framing. Using the 12X12" Glass pieced sheets for this application. Question is - Is there any other method of prep and installation aside from 1\4" Hardiboard screwed and thinset?
I'm trying to minimize the projection. Glass with matting is about 9\32". I do have a 1 1\2" backsplash that it will rest on, but if I can, I'd like to keep as much reveal as possible.
Is there another acceptable adhesive possibly that would minimize the space that thinset will use up? Contact cement is a little risky as it is a vertical application in a cramped space and could require a bit of adjusting as it is set in place.
Any feedback would be appreciated.
If you don't have time to do it right, when will you ever have time to do it over?
jackofmany is offline   Reply With Quote
Old 07-25-2011, 04:50 PM   #2
Rewards Points: 5,336
Put the tile on the sheetrock. No need for the hardiboard. Silicone caulk the 1/8" gap where the tile comes down to the counter.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
jackofmany (07-26-2011)
Old 07-25-2011, 06:39 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Agreed! Scuff the paint and go for it.
Thinset won't take much more space than anything else. Not all adhesives will work for glass tiles. In fact the tile maker should have a recommendation of which thinset is suitable to use.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
Old 07-26-2011, 08:35 AM   #4
Rewards Points: 79
Thumbs up
Need to Inquire
Thanks to both of you for the responses. I have the store (Depot) where my daughter bought her tile and will head over today to get the proper Thinset. It's heck doing a job thats 2 hours away. I definately want to have everything I need. Think I'll carefully heat strip the new paint. It's 4 new coats - total of satin latex. Might just peel off and leave me with the old painted sheetrock. Gotta get it into the heads of these youngsters - Think Ahead, it saves time and money.
Old 07-26-2011, 08:57 AM   #5
Learning by Doing
Leah Frances's Avatar
It's super nice of you to do all this for your daughter.... I bet she would really learn something if you did it together
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
tile backsplash dvav340 General DIY Discussions 1 11-27-2010 09:18 PM
installing shelving on tile backsplash indignatz Remodeling 7 11-05-2010 07:06 AM
bathroom floor tile job advice needed dbrew Flooring 14 01-23-2007 08:03 PM
Ceramic Tile Backsplash Installation DK75 General DIY Discussions 4 11-01-2006 08:56 PM
need contractor advice for laying kitchen tile ng622 Flooring 5 12-07-2005 11:28 AM
