Old 11-15-2008, 03:53 AM   #1
Glass on greenhouse roof
I am new to the forum and need some feedback on a project that I am undertaking. I am building a wooden framed greenhouse (12' x 16') and am needing help/ideas on placing tempered glass sheets between the truses which are 24 inches on center. I want to place the glass sheets flush with the top of the trusses to eleminate standing rain or snowmelt, etc. I do not want to place the glass in anytype of frame that would make it recessed because of problems with standing water, leaves, dirt, etc. which would eventually rot the wood.
What suggestions does anyone have as to treatment/installation on the bottom edge of the glass which will be as stated, flush with the trusses? (For the glass on the walls I will install drip edge). The roof glass will be surrounded with butyl rubber and will be held in place with an inverted "U" shaped cap (channel) with a lip on each side to rest on the vertical sides of the glass. The top edge of the glass will be held by plywood lapped to fit the top of the glass. Has anyone out there built a greenhouse with this type of glass installation?
Sorry for such a long post but it is my attempt to provide enough information to those responding.
Flavio is offline   Reply With Quote
Old 11-15-2008, 08:14 AM   #2
the Musigician
DangerMouse's Avatar
i think a silicone adhesive caulk should take care of it just fine.
post some pics when it's done?
DM
RU Crafty? Come join us at www.CraftForum.com !!!
For some Magical Fun, go to:
http://www.youtube.com/user/MickeySoume
Now Featuring: My Canine Assistant Picks the Magic Rising Card!
Old 11-15-2008, 04:19 PM   #3
Old fart still learning!
Maybe it's just me, but if you put the "bottom edge of the glass which will be as stated, flush with the trusses" would that not put the glass on top of the trusses?
Or, how will the glass go "between the truses" if not recessed to some degree?
Does "glass sheets flush with the top of the trusses" mean that you want the top of the glass flush with the top of the trusses and between them? If so, some kind of stop has to be under them, either a piece of molding, or a rabbet cut into the edges of the trusses, or something. Not recessed as such, but just down equal to the thickness of the glass.
By the way, I would also prime and paint the wood.
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Old 11-15-2008, 09:57 PM   #4
Thanks for your input. DM I will try to make it a point to post some photos when I complete this project.
Downunder..... I guess my explaining was not as clear as it could have been. I have painted the trusses with three coats of white oil based barn paint with boiled linseed oil added. Actually, as suggested, I plan on putting a piece of wood between the trusses down from the top edge of the 2x4's the thickness of the glass. The glass will sit on this trim and will put the glass at the same level as the truss member. My plan is to center the 5 ft long piece of glass between the trusses which are eight ft long. This will leave some space on top and bottom of the glass for plywood which I was thinking of covering with wide roof flashing. Because of leaks that will probably appear, I am now wondering if the glass should be placed clear to the bottom of the trusses even with the outside walls. Any thoughts on this?
Old 11-16-2008, 12:53 AM   #5
Be very careful to protect the edges of the glass. Tempered glass can take a lot of abuse but if the edge is hit it will shatter. You should allow room to put screws in to hold the glass down. If you hit the glass with a screw it is not very forgiving.
I am doing almost the exact same thing. It is going to be a solarium rather than a greenhouse and I am using double glazed glass.
My plan is to put the glass on the joists with caulking, then put a small lip at the bottom to keep it from sliding down (protected from hitting the edge with caulking) and then put some aluminum cover plate like this. I will use some Redgard between the glass and then caulk the cover plate where it meets the window.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 11-16-2008, 10:06 PM   #6
Marvin....Will you be using the same technique on the wall studing???
Old 11-17-2008, 12:53 AM   #7
The walls will be sliding glass patio doors. I have 6 of them I got out of several remodels that the owner were just glad to see them go away.
I really want one of these.
http://www.nanawall.com/gallery/view...ashembed&mid=2
Oh crap, I just drooled all over myself.
Old 11-17-2008, 01:59 AM   #8
Marvin never saw anything like those doors before. Do you know where they might be giving some of them away? I can see why you would like them.
Old 11-17-2008, 03:08 AM   #9
If they were giving them away I wouldn't be telling anyone until I got all I needed.
Price is between 9k and 50k.
Old 11-17-2008, 12:40 PM   #10
I understand
Old 11-17-2008, 01:37 PM   #11
bradnailer's Avatar
Watching Norm on the New Yankee Workshop once, he built a greenhouse and used some type of lexan for the roof. It was double paned with channels running between the upper and lower panes. He built frames for the panels. Might google NYW and see if they have the plans.
bradnailer is offline   Reply With Quote
Old 12-04-2009, 01:10 PM   #12
So now a year later I am thinking about doing something similar.
How did your project turn out? Does it leak?
What did you finally do to keep it from leaking?
And what was the pitch, and were you concerned about snowfall?
Fred
eichelman is offline   Reply With Quote
Old 12-04-2009, 01:33 PM   #13
Extreme DIY Homeowner
Scuba_Dave's Avatar
I used old sliding glass doors that people were throwing out - free
Tempered in case something happens
They have been out in heavy snow storms (18"+) & held up
They are installed almost flat - so hold a bit of weight
The jalousie glass windows on sides & front were ~$75
Mine is sealed up - but not waterproof
Since its a greenhouse I see nothing wrong with water getting in
Mine is buried into the ground ~1'....maybe a little more
DIY Chatroom Moderator
Not a Pro or for hire, I have enough to do on my own house, Just Look !!
http://www.diychatroom.com/-ongoing-37438/
Please fill out Location in your profile (User CP), then we can answer your question
If a code reference is needed for one of my posts please access NEC 2008 & read
http://nfpaweb3.gvpi.net/rrserver/browser?title=/NFPASTD/7008SB
Scuba_Dave is online now   Reply With Quote
Old 12-04-2009, 07:35 PM   #14
Thanks for the picture and details;
I agree, a greenhouse doesnt need to be waterproofed.
The one thing better than recycling is reusing!
Congratulations,
Fred
Old 12-05-2009, 12:18 AM   #15
Hello all...I am in the final stages of completing my greenhouse project. A natural gas suspended heater has been purchased and installed though not hooked up yet as I have to run some gas line. The wiring has been done with three four tube flourscent light ceiling fixtures and wall recepticals run approximately every six feet or closer along the walls. These are protected with Ground Fault Circuit Interrupters. A large fan has been installed on the ceiling and a ceiling fan has also been installed. Mostly all of my items were purchased second hand, The lights were advertized on Craigs Listing as leftovers from a Condo building project and were never used. I am waiting to install the metal roof as it to cold at this time. i've got to put the final sealants on the roof windows as well. Presently the roof of the greenhouse is covered with clear plastic which has to be replaced from time to time. I will post photos in the future.
More On This Topic
Learn how to adjust the truss rod to setup a fender stratocaster electric guitar in this diy guitar tech video. Read More »
So the first of the issues that we want to look at is whether or not the neck is warping or bowing in any way. And so we'll use our steel rule, and lay it on the frets themselves in between the strings, in this case, and while it's laying on the edge, we... Read More »
Hi i'm Frank Pope FBI guitarist. We want to measure. We are going to run a test piece through it. Go very slowly. You want the cut no more than 1/3 of the length of the router bit. Cut it to correct length and you are done with the tool. Read More »
Two common materials used in today's greenhouses to get around the problems that we would have with glass is to use a polycarbonate. And the polycarbonate has certain advantages. One, it's very resistant to damage by snow, hail, wind and other features... Read More »
Determining when you need to place a shade cloth on your greenhouse and how much coverage you need is tricky. You want your plants to get enough sun, yet not too much. Depending on the type of plants you are growing and the growing season, utilizing a... Read More »
"Defogging" double-pane windows .... a gimmick?? alexz General Discussion 133 03-10-2010 02:35 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing 18 11-07-2008 06:08 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing 4 11-19-2006 08:17 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
