Old 11-05-2009, 04:52 PM   #1
Default Glass Blocks on top of Bathtub? weight?
i was thinking of doing this project but wanted to ask before attempting. i have a standard steel bathtub and wanted to build a glass wall on half of it 30" x 64" using standard glass blocks. my question is, will the edge of the bathtub be able to handle the weight of the blocks, mortar and reinforcement bars. is it at all possible to do this without ripping out the tub and makeing a walkin shower.
Let me know.
EuroZ24 is offline   Reply With Quote
Old 11-07-2009, 08:47 AM   #2
Glass
Hmm, very risky, depends on your bathtub really.
I wouldn't risk it just for the safety reasons and really, on your place I wouldn't rely on forums for answer with such a risky question
I remember ages ago on a different forum I asked if a standard glass splashback can be used for a kitchen worktop, and how heavy it will be and if two people can carry it, and everyone was like "yes yes, you'll be fine".
Needles to say, week after that I had 4 people carry the worktop. Some questions just can't be answered on forums
Krystian Glass is offline   Reply With Quote
Old 11-07-2009, 10:10 AM   #3
You would not build the glass block wall on the tub. If you want glass block, build it next to the tub. If you can't build it next to the tub for some reason, move on to another project.
Ron
Old 11-07-2009, 10:40 AM   #4
I agree with Ron you dont build it on the tub build it next to the tub.You can have it go right up to the edge of the tub without the weight setting on the tub itself.If you have the room you can make a surround for around the tub to blend in with the wall you want
clasact is offline   Reply With Quote
Old 11-08-2009, 11:40 AM   #5
you can do this without setting on tub. Use an aluminum lintel bolted to wall that blocks can rest on. The lintel is a piece of angeled metal , you can talk to the glass block people for thickness and size for weight of wall requierments. You will need to add fasteners from block to wall studs as you go up to keep wall from moving out of vertical
More On This Topic
You can choose many different sizes and styles of glass block for decorating. The block comes in 4- to 8-inch squares and in a variety of smooth, textured, clear, and diffused styles. Before choosing your glass, decide how and where it will be used, so... Read More »
Ok, next, let's come to some bath wear. The first one I would like to teach you is the bath tub. Yu gang. Yu in Chinese, it means bath, gang tub, so very easy to understand, because yu means bath, so it has the water radical and this is the last part... Read More »
Hi, I'm Liz Hood on behalf of Expert Village and right now I am going to be talking about certain things that you will need to buy to give your new baby a bath. Now, this right here is a baby bath tub. It has a little duck hammock drapped across the top... Read More »
Bathtubs can be dangerous places for those with disabilities. It's important to lay out the bathtub area carefully to provide optimum safety. Depending on your budget and space, there are a variety of modifications that can be made to help insure a safer... Read More »
Keeping your bathtub clean means cleaning it weekly and maintaining it daily. If you do this, and follow the steps provided, you'll save yourself a lot of scrubbing and you'll keep your tub looking nice and clean. Read More »
"Defogging" double-pane windows .... a gimmick?? alexz General Discussion 131 11-16-2009 11:39 AM
Replace window in shower with glass blocks organick Kitchen & Bath Remodeling 6 10-10-2009 11:45 PM
Glass on greenhouse roof Flavio Building & Construction 10 11-17-2008 01:37 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 12:42 PM
Glass or acrylic blocks ? amakarevic Building & Construction 2 03-31-2008 08:14 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
