Glass Blocks In Place Of Railings - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-24-2011, 01:25 PM   #1
Glass Blocks in place of railings
So we wanted to replace the railing on our second floor landing with glass blocks (planned on using 8" blocks on a 10 foot run, up about 4 feet). A couple questions on creating this wall.
Will using morter create a high strength wall? Worried with all the kids running around soon...
Do i need to build a frame on all 4 side? I have hardwood floors and 2x4s on on side to strap into
If i can just tie the wall into the floor/1 wall can i use the rounded blocks for the top cap/opposite side?
fixerupper84 is offline   Reply With Quote
Old 02-24-2011, 01:30 PM   #2
Old School
Willie T's Avatar
I doubt just glass blocks, by themselves, will provide the required 250 pound lateral resistance.
Willie T
Old 02-24-2011, 02:55 PM   #3
Rewards Points: 558
it would have to look like this when you install it in place of a railing
Here are instructions on what to do: http://www.accentbuildingproducts.co...s/mortar12.pdf
epson is offline   Reply With Quote
Old 02-26-2011, 01:09 PM   #4
Luxury Mahogany Doors
DecoDesignCente's Avatar
Why don't you consider glass railings instead. You can get the custom glass railings with either aluminum or stainless steel brushed for the post?
DecoDesignCente is offline   Reply With Quote
glass tiles over kerdi (thinset question) Queso Bandit Remodeling 12 05-15-2012 04:08 PM
Moisture on windows baum Building & Construction 56 12-22-2009 06:39 PM
glass block window Morjade Building & Construction 1 04-23-2009 07:32 PM
glass tiles over kerdi (thinset question) Queso Bandit Tiling, ceramics, marble 1 04-17-2009 01:39 PM
Custom built legs for very large glass tabletop joeyboy Project Showcase 8 10-06-2008 11:48 PM
