Glass Block Installation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-11-2008, 05:49 PM   #1
Rewards Points: 150
Glass block installation
I just noticed that who ever put the glass blocks in our basement window placed the vent square right next to a deck joist. I need to move the vent square down one row and put the glass one up.
Do i chisel them out? How do I install a new one.
Cossack is offline   Reply With Quote
Old 08-11-2008, 06:49 PM   #2
Whatamess
Take some pictures and some one will get you on the right track.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 08-12-2008, 07:01 AM   #3
BUILDER / REMODELING CONT
buletbob's Avatar
You will have to get a concrete blade installed on a grinder and cut the mortar out from around the block first, inside and out. If you where to just break the block to remove it you will mostly break the one next to it. depending on how many block high your are there is also the possibility of reinforcement wire mudded into some horizontal coures. so be careful. BOB
Old 08-12-2008, 02:17 PM   #4
Rewards Points: 150
Am I going to be able to save the blocks I cut out? I don't have a grinder, but what about a dremel with the right bit?
Old 08-12-2008, 03:24 PM   #5
Advice worth 2 cents!
Rewards Points: 150
Personaly, I don't like the Dremel tool for much. I'd probably use a 4" grinder with a diamond wheel. (you can get a really cheapo one from China that can easily do the job)
-pete
dudes, I know, but being that the Olympics are in China maybe we could give them a break (no more than 2 weeks)
---pete
HandyPete is offline   Reply With Quote
Old 08-12-2008, 03:52 PM   #6
buletbob's Avatar
you will only be able to cut the width of the blade. which is only 1". The glass block are anywhere from 3-3/8" to 3-3/4" thick. the grinder would work much more efficient. you will have to cut both sides.
And plan on breaking a block. It most definitely can be done with out breaking one but the odds are against you as per never doing this before. If one breaks you can get a replacement for around $8.00 A block.
Installing vent in glass block window jasoncw Building & Construction 6 09-27-2009 10:57 AM
Glass block window position?? justdon Remodeling 4 09-28-2008 06:29 AM
rough opening for glass block oxicottin Remodeling 5 05-04-2008 08:01 PM
Glass Block basement windows Colonial Building & Construction 2 03-18-2008 12:20 PM
Glass Block jtbroderick Remodeling 1 04-16-2006 02:37 PM
