Glass Block Basement Windows - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-18-2008, 11:46 AM   #1
Glass Block basement windows
I am looking (attempting) to install 4 glass block windows in my basement, one of which will have an inlet and outlet pipe spacing for a horizontally venting furnace. I figure the other ones I will install a vent in for moisture control and air movement.
I have a few questions that maybe someone here could help me with;
1) would it matter if I use 3" or 4" thick block? I have the option of buying either used.
2) would it be best to make the window first and then transfer it to the actual window?
3) from researching these online (as I have never installed them) it looks like silicone would be the best method rather than mortar.
Any help with this (my first post ) would be most helpful.
Colonial is offline   Reply With Quote
Old 03-18-2008, 01:14 PM   #2
Rewards Points: 1,220
4" are recommended for exterior usage, and I prefer to build it in place with mortar.
Tscarborough is offline   Reply With Quote
Old 03-18-2008, 01:20 PM   #3
Thanks for the suggestion. I like the 4" style of the used ones I found better anyway so that works out. $1 a block doesn't seem like a bad deal...
Do you have any recommendations of books to read up on for installation? This would be my first attempt and I know that I can pull out all of the old sills. Most of them are rotten anyway.
Installing vent in glass block window jasoncw Building & Construction 6 09-27-2009 11:57 AM
glass block windows jay2331 Remodeling 1 11-24-2007 02:53 PM
Replacing Glass In Windows OVRMYHEAD General DIY Discussions 1 04-26-2007 07:07 PM
Glass Block windows... daveincincy General DIY Discussions 1 07-18-2006 11:08 PM
