Getting Water Out Of The Wall... - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-05-2008, 11:51 AM   #1
Unhappy
Getting water out of the wall...
Hello all - I'm a recent first time home buyer - condo buyer actually.
Any suggestions on how to get water trapped behind a brick wall out?
Here's the back story:
A couple of months after moving in I started to get some efflorescence and moisture wicking in through a brick wall and SLOWLY dripping down onto a new hardwood floor.
It ends up the mortar in the gap between my brick wall and the abutting building's wall only went up for the first 10ft of a 4 story building, allowing for a 1/4-1/2" gap that could fill with water.
The gap has now been mortared, and the roof is well sealed, but there is still water coming through my wall.
So my feeling is that there is a 'reservoir' of water behind the wall that has to come out before the moisture leaking stops.
Any ideas?
-Chuck Smith
Brooklyn, NY
Getting water out of the wall...-mineral-deposits-s.jpg   Getting water out of the wall...-1_weeks_worth_water.jpg
cssmythe3 is offline   Reply With Quote
Old 03-05-2008, 03:07 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,602
Ayuh,... Drill a Hole in it, down low....
Old 03-06-2008, 08:27 AM   #3
so-elitecrete
Rewards Points: 150
you problem's exacerbated,,,
w/o your realization 'cause the waterways've been created outside,,, drilling drain holes'll alleviate the wtr but don't be surpris'd when more flows inside,,, exterior excavation & positive-side work's a more permanent solution imo.
so-elitecrete is offline   Reply With Quote
Old 03-06-2008, 02:55 PM   #4
Bondo's Avatar
Ayuh,.... They said it's been Fixed on the outside....
Old 03-06-2008, 04:07 PM   #5
you need some sort of expansion joint cover. it should have been allowed to drain and never had mortar in it to start. My guess is you have no through wall flashings, weeps etc. You need to call someone to investigate your problem. To provide any more help, you need to post a lot more pictures. From the outside, etc.
ncgrogan is offline   Reply With Quote
Old 03-07-2008, 05:14 AM   #6
so-elitecrete
Rewards Points: 150
that original opening,,,
has been nam'd a ' slot drain ' by many bldrs & waterproofers,,, its a space formed when the floor's pour'd on top of the footers,,, sealing it's caused the wtr level to rise on the exterior of the wall,,, w/o banging open the floor & installing a ' french drain ', there is a system that seals the floor/wall intersection call'd a ' cove system ',,, google it & see for yourself,,, but you'll still have to drill ' weeps ' to drain that wtr out of the wall.
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Sump pit filling with water in dry weather dimitar Building & Construction 13 12-19-2007 11:59 AM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
How to Space Water Heater Flue Vent from Outside Wall? austinbirdman Plumbing 1 03-12-2007 10:28 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
