Getting Slab Poured Soon.. . Need Help With Roof - Building & Construction - Page 4 - DIY Chatroom Home Improvement Forum
Old 01-08-2008, 09:52 PM   #46
Fire Fighter-
Klint's Avatar
on of the contractors gave me a quote, here's what he said.
Just to put down the felt paper and shingles would run about $ 600.00. If we have to frame the roof , install the decking and the shingles, it would be $ 1,400.00. To do all the framing for the walls, roof, decking and roofing would be $ 2,450.00. These prices are labor only as you indicated.
Which I just want the roof so $1,400 in labor.. What you guys think good price??
Thanks,
Klint T.
Klint is offline   Reply With Quote
Old 01-08-2008, 11:11 PM   #47
Home Renovations GC
kiwi54's Avatar
take 400 square feet........$3.00 to $3.50......that seems very reasonable for framing, sheathing, flashing and shingles.....I'd charge more and get it.
$1400 for peace of mind is a small price to pay.....less than I thought...
Quote: Tis better to stay quiet and be thought a fool than to open one's mouth and remove all doubt.
kiwi54 is offline   Reply With Quote
Old 01-08-2008, 11:40 PM   #48
Fire Fighter-
Klint's Avatar
Framing of the walls menas just the studs put up correct? I would still need to hang the drywall nad stuff.
Thanks,
Klint T.
Old 01-09-2008, 12:29 AM   #49
Yep. Should include wall sheathing and house wrap as well.
pavola is offline   Reply With Quote
Old 01-09-2008, 12:45 AM   #50
Klint, have them get more specific so you definately know the end cost. (written, of course) Doesn't matter if they're good friends or good referals.
Does this include tie-in to the existing roof? Removing shingles as necessary for proper valley underlayment? Ice guard? Drip edge? Installing and flashing skylights?
$800 for roof framing. Includes skylight openings?
IMO, it's a very good price. Get written quotes/contract that point the options you want and include all necessaries. This is where a tight budget demands attention.
Old 01-09-2008, 09:01 AM   #51
Fire Fighter-
Klint's Avatar
What do I need to watch out for??
Thanks,
Klint T.
Old 01-09-2008, 09:47 AM   #52
Rewards Points: 896
Communication. Make it clear - you just want the roof framed, tied into existing, and finished - you will be doing the rest. You want the lines to duplicate your existing rooflines in so far as pitch, soffit overhang, etc.
So your wall framing should meet up with your existing walls. In the end you have one homogneous structure that doesn't look like it was a cheap tacked-on, lean-to addition.
LawnGuyLandSparky is online now   Reply With Quote
Old 01-09-2008, 08:30 PM   #53
Your money. And quality work.
Everything you want and expect should be in written quotes so both you and the contractor know what's expected of them and you know what should be you final cost. Your job is to spell out what those expectations are. If you want more than what's in that contract once they've begun, expect to pay for it. Once you chose the contractor, have a contract signed with terms of job description and cost. Payment terms - only pay the balance after completion. Partial payments are common but keep payments in proportion to completion status. Downpayments shouldn't be necessary for labor quotes of this size. Require them to fix any inspection failures that come under their job description. Understand that this is an incomplete list too, just some of the important ones.
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 10:44 AM
Ventilating Roof with no ridge? NateHanson Roofing/Siding 7 12-30-2007 05:33 AM
I need help Re: Poured Slab Foundation - Moved to Plumbing alextina Plumbing 6 04-19-2007 05:35 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
Venting a shed roof with 2/12 slope atulc Roofing/Siding 5 08-25-2006 08:28 AM
