Getting Rid Of Weeds From Concrete Joints - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-25-2011, 10:27 PM   #1
Getting Rid of weeds from concrete joints
I have concrete poured in my back yard, but I have been noticing that weeds/grass grows up at the concrete joints. I am thinking of installing tiles on top of the concrete so that no weeds show up from those joints. The area for the tiles shall be around 5000 sq. ft and the cost of getting tiles installed shall be quite a lot.
Can some one suggest me a proper solution at a reasonable cost?
I want my back yard concrete to be presentable.
Thanks,
Kris Gossain
Kris Gossain is offline   Reply With Quote
Old 12-25-2011, 10:39 PM   #2
Rewards Points: 13,732
Let me guess, you have been using Round Up but it comes back in a few weeks.
Not going to ever work.
Clean out the cracks with a pressure washer or high pressure garden hose and let dry. Now use total vegitation killer. Now it will stay gone for 12 months
Old 12-25-2011, 11:41 PM   #3
Facilities Maintenance
Ever thought of using a pressure washer?
BigGuy01 is offline   Reply With Quote
Old 12-26-2011, 12:21 AM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,824
In most cases, the weeds are caused by seeds that have blown into the crack....so, doing like joecaption will work well....I would take it a step futher....fill the cracks with gray RTV....that will keep the seeds from having a place to land.
ddawg16 is online now   Reply With Quote
Old 12-26-2011, 06:22 AM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,360
Ayuh,... I agree, 'n the pavers will do the same thing, with alot more cracks to fall into...
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 06:25 PM
Tips For Pouring Concrete? Root issues? Thoughts? kronic24601 Building & Construction 5 02-14-2011 06:52 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 04:53 PM
weeds growing from concrete cracks on stairwell amakarevic Landscaping & Lawn Care 1 07-13-2008 07:40 AM
