Old 02-17-2009, 10:52 AM   #1
They're all fixer-uppers
J187's Avatar
Getting ready ro refinish my hardwoods, I would like to add to it as well...
As you can see from the pic, I have a tile kitchen floor and hardwoods throughout the dinning room, living room and halls. I am getting ready to sand and change the color of the floors. I would like to ditch the tile in the kitchen and carry the hardwoods throughout. I am guessing my best course of action would be:
Find unfinished hardwood flooring that matches the size and style of my current.
Rip up the kitchen floor and install the new unfinished flooring.
Sand the existing floors.
Finish all floors at once.
Is that right? Anything to add? And specifically, would you guys seperate the kitchen from the other rooms with thresholds or just carry the floor through smoothly?
J187 is offline   Reply With Quote
Old 02-17-2009, 11:02 AM   #2
the Musigician
DangerMouse's Avatar
i'm guessing when you rip up the tile floor, you're going to find the same flooring as the next room. be careful taking up the tile and you may not need/want new. otherwise, your ideas are all ok. although you did not say how dark you are planning on staining, keep in mind the lighter the color, the better it hides *whatever* dirt, scratches, etc.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 02-17-2009, 11:03 AM   #3
the Musigician
oh yeah, and you'll probably want to replace the tiles on the wall with matching baseboards... Po)
DM
Old 02-17-2009, 01:51 PM   #4
J187's Avatar
Thanks. I am quite curious to see whats underneath. I am going with brazilian cherry I think on the floors. We'll do our best to keep it clean. No kids, no pets and we don't wear our shoes in the house.
Old 02-17-2009, 03:03 PM   #5
Remodeling Contractor
No shoes... ask you doc... very bad for the kids feet!
Old 02-17-2009, 07:28 PM   #6
the Musigician
i wonder why they laid the board and tile over the wood in the first place? you may find a huge grease stain or burn spot or something... lol
but you may luck out like we did in our last home and fine nice wood under that was easily cleaned up, sanded and refinished like new.
DM
Old 02-18-2009, 10:20 AM   #7
J187's Avatar
Kids??
DM
So I pulled a tile underneath the sink area, turns out its that it's plywood underneath.
Old 02-18-2009, 10:34 AM   #8
the Musigician
just the tile? it looks like there's a sheet of backerboard/ply under the tiles, yes.
also, under the sink may not have nice flooring. i've seen it torn out because of water damage and redone with a sheet of plywood.
try to _carefully_ pry up the tile and board at the existing hardwood floor level in that doorway you show and take a peek. that should tell you what continues under it.
DM
Old 02-19-2009, 10:23 AM   #9
J187's Avatar
I think the picture is decieving... the tile and the hardwood are exactly the same height at that threshold. What you see is some strange attempt at a threshold - its a different color grout used to transition between the wood and tile... from under the sink, I pried up the first tile toward the floor, which means its the tile located in front of the cabinet, not directly under, and its definitley ply underneath....
The only slight problem is, I'm now having slight doubts as to whether I should repalce the kitchen tile with newer updated tile rather than continuing the hardwoods - what would be your opinion? Anyone else?
Old 02-19-2009, 10:34 AM   #10
the Musigician
oic, yes, that is hard to tell. welp, your options are wide open now! retile, cork, hardwood, carpet, whatever you like!
DM
Old 02-19-2009, 11:23 AM   #11
J187's Avatar
what would be your preference if it were your house
Old 02-19-2009, 11:35 AM   #12
the Musigician
so many variables..... dogs? kids? grandkids? traffic? how klutzy you are... lol it seems to me for your case to be what styles do you like? what can you afford? what does the WIFE want????? i'll be doing my new kitchen in cork, if that helps.
DM
Old 02-19-2009, 12:16 PM   #13
with dogs use tile. Do not like tile use bamboo.. must harder
Old 02-19-2009, 02:16 PM   #14
J187's Avatar
Thanks. No kids, no dogs, no pets. My wife and myself. We're very careful people. I'm thinking from aesthetics only. I think I'm going to continue the hardwoods throughout. What's the best way to determine what kind of wood floor is there now?
Old 02-19-2009, 02:26 PM   #15
By the grain. Look online to match the grain to pictures available. Most are oak, some old floors are pine.
Getting pond ready for fish? sandyman720 Landscaping & Lawn Care 9 08-01-2008 11:54 PM
removing glue from hardwoods david81 Flooring 2 05-24-2008 11:37 AM
New construction ready for roofing... MLO Roofing/Siding 2 11-03-2007 03:46 AM
Refinishing hardwoods J187 Flooring 2 10-26-2006 11:35 AM
Are all hardwoods (flooring? created equal??? ahnniem Flooring 2 01-28-2006 02:17 PM
