Getting Corner Posts Level On Unlevel Ground - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-10-2008, 07:04 PM   #1
Getting corner posts level on unlevel ground
Im ready to start putting up the corner posts for my pole building. The area i have ready for the building is relatively flat, but not completly. I got it as close as i could. How can i get all of the corner posts to be the same height if the groundis uneven? I don't want to have my building be lopsided.
jk333 is offline   Reply With Quote
Old 11-10-2008, 08:30 PM   #2
Theres more then one way.
iMisspell's Avatar
Rewards Points: 150
This is just a suggestion...
A laser level
or
string and "line levels"
The way i would go about this is make the tops of your posts footings level and then you will not have to worrie about the posts length.
You could dig your post footings, pound some scrap 2x4's or something into the ground on the back sides of each hole, run string from 2x4 to 2x4 (creating a box) and get the string level. Then set the sonet-tubes so there tops just touch the bottom of the string and it should be nice and level.
Im sure others will have different or easier ways to go about this.
_
~ What was once an opinion, became a fact, to be later proven wrong ~
My current learning experience - 22x22 addition - Work shop, music-room, master bedroom above..
iMisspell is offline   Reply With Quote
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
Ground level deck questions 4just1don Carpentry 7 06-30-2008 07:57 PM
Removing wooden line posts from ground bigolepaul General DIY Discussions 3 05-21-2008 06:20 AM
Hot Tub Install--Grounding Rod Question statgeek_rob Electrical 16 09-15-2007 02:59 AM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 06:30 PM
