Old 01-10-2011, 08:20 PM   #1
General Steps to a bathroom remodel
Hi all,
I'm about to undertake a bathroom remodel. I've purchased numerous books, and have been reading and researching this for some time. However, one rather important detail eludes me: the order of the major parts of the process. My understanding, at the moment, is something like this: (where the a's and the b's could be done at the same time)
1. Gut
2. Drywall on ceiling (only hang it to keep the heat in while we remodel)
2a. Electrical rough-in / redo if needed
2b. Plumbing rough-in
3. Tub and tub surround installation
4. Hang drywall on the walls
5. Mud and tape
6. Install flooring
7. Seal/prime and paint (maybe do this before floors are installed?)
8a. Install vanity & sink
8b. Install commode
Your help, experience, and advice are most appreciated.
jdt141 is offline   Reply With Quote
Old 01-10-2011, 08:32 PM   #2
hey friend.
here's how i would do it:
1) gut
2) assess structure and modify/repair as necessary. will you be adding tile? are the joists stiff enough? how old? spaced how far apart? what will your subfloor
be?
3) plumbing rough-in/updating
3a)mechanicals - fan/vent?
4) electrical (make sure dedicated circuit for 20amp GFI at sink)
5) insulation (if any exterior walls)
6) install tub
7) hang and tape sheetrock everywhere
the rest is good. you can do finished flooring or painting first, whatever you feel most comfortable with. if tile, i would probably paint first, then touch up after floor installation.
good luck.
wombosi is offline   Reply With Quote
The Following User Says Thank You to wombosi For This Useful Post:
oh'mike (01-10-2011)
Copper to pex manifold on bathroom remodel jpeake Plumbing 5 11-16-2010 04:59 PM
Noob bathroom remodel jep Kitchen & Bath Remodeling 18 11-22-2009 11:56 AM
Bathroom remodel runningirl Building & Construction 11 07-26-2009 06:54 PM
My bathroom and kitchen remodel vetting Project Showcase 17 04-25-2009 10:36 AM
Planning my Bathroom Remodel benshouse Plumbing 1 01-06-2009 09:23 AM
