#1 |
gate repair
I am trying to install an anti-sag gate kit, but have run into a problem. I need to find out how I can put in screws on the bottom board when there is only about 4" clearance from the ground to the board. Obliviously I can get the side screws in, but not quite sure how I am suppose to screw into that bottom piece. there is not enough room for a regular screwdriver, let alone a power one. Suggestions please - I have limited tools.
#2 |
MXer
gate repair
Remove the gate, install the screws, reinstall the gate.
#3 |
gate repair
I know, it sounds simple enough, but I am not able to do that by myself. The gate is big and way too heavy. I would like to figure out how it could be done without someone having to help me. I know, I am too darn independent-been told that all my life. Thanks anyway!
#4 |
gate repair
Angle screw driver attachment. http://www.amazon.com/Milwaukee-48-3.../dp/B0000224AW
#5 |
gate repair
thanks, I had no idea there was such an attachment. I will see if i can find one locally first.
#6 |
gate repair
lowes has them, just not on their site that i can see. Otherwise matco and snap-on are where i used to get them.
| The Following User Says Thank You to gmhammes For This Useful Post: | tori (04-12-2010) |
#7 |
gate repair
what type of material is the ground?
you could always dig a small hole, open gate over the hole ... attach screws. no cost if you can do it this way. |
#8 |
gate repair
It is concrete-----so that is not an option. thanks anyway!
#9 | |
gate repair
there are also 'flex shaft' screwdrivers available.
| The Following User Says Thank You to jlhaslip For This Useful Post: | tori (04-13-2010) |
| Display Modes | |
| $1440+ labor only repair on 3 yr. old Goodman unit!?! | JMK | HVAC | 23 | 05-06-2012 11:45 AM |
| Choosing a Refrigerator based on Repair Value | 1655graff | Appliances | 5 | 03-01-2011 09:49 AM |
| Repair Compounds | saggdevil | Painting | 3 | 04-25-2010 04:02 PM |
| Driveway Gate Construction Questions | KP Texan | Building & Construction | 3 | 07-30-2009 09:45 PM |
| Gate for wooden privacy fence | RookVega | Landscaping & Lawn Care | 2 | 11-09-2008 10:56 AM |
