-   -   gate repair (http://www.diychatroom.com/f19/gate-repair-68836/)
tori 04-11-2010 07:10 PM
gate repair
1 Attachment(s)
I am trying to install an anti-sag gate kit, but have run into a problem. I need to find out how I can put in screws on the bottom board when there is only about 4" clearance from the ground to the board. Obliviously I can get the side screws in, but not quite sure how I am suppose to screw into that bottom piece. there is not enough room for a regular screwdriver, let alone a power one. Suggestions please - I have limited tools.
3 legged dog 04-11-2010 08:25 PM
Remove the gate, install the screws, reinstall the gate.
tori 04-12-2010 09:04 AM
critical peice of info
I know, it sounds simple enough, but I am not able to do that by myself. The gate is big and way too heavy. I would like to figure out how it could be done without someone having to help me. I know, I am too darn independent-been told that all my life. Thanks anyway!
gmhammes 04-12-2010 10:29 AM
Angle screw driver attachment. http://www.amazon.com/Milwaukee-48-3.../dp/B0000224AW
tori 04-12-2010 10:46 AM
great option!
thanks, I had no idea there was such an attachment. I will see if i can find one locally first.
gmhammes 04-12-2010 10:49 AM
lowes has them, just not on their site that i can see. Otherwise matco and snap-on are where i used to get them.
bbo 04-12-2010 12:43 PM
what type of material is the ground?
you could always dig a small hole, open gate over the hole ... attach screws.
no cost if you can do it this way.
tori 04-12-2010 01:22 PM
It is concrete-----so that is not an option. thanks anyway!
jlhaslip 04-12-2010 07:53 PM
there are also 'flex shaft' screwdrivers available.
