Gas Piping Pressure And Leak Form - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-05-2013, 01:28 PM   #1
gas piping pressure and leak form
where can I find a standard for for a gas line pressure and leakage test
MEDSERVICETEC is offline   Reply With Quote
Old 02-05-2013, 02:28 PM   #2
Rewards Points: 1,294
Your supplier can tell you what pressure they supply in your area. As for leak testing the gas companies in my area like to see 3-5 psi on the line. Most times though they just do a dial test for 15 min. If it a new install or a repair then they want the air on it
danpik is offline   Reply With Quote
Old 02-06-2013, 05:32 PM   #3
retired union carpenter
Send a message via Yahoo to coupe
for leakage test, I use Windex or liquid soap on all joints and look for bubbles
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 02-06-2013, 05:35 PM   #4
Rewards Points: 13,296
The gas supplyer should be doing the testing and there going to do it for free so it will not go boom.
Old 02-06-2013, 11:58 PM   #5
OP should add his location. Here the test is 15 psi for 15 min, but some inspectors want 30 for 30. Every area is different. Soap test only is for final connections, but also needs to be accompanied by a dial test if gas is metered. Also, not all gas suppliers do work on the customers side. Here you need to hire a gas contractor to do any gas work, unless the local authority lets you do your own work. Bottom line, check your local codes and regulations.
hvac benny is offline   Reply With Quote
Old 02-07-2013, 06:17 AM   #6
Not in all areas. In my area we have to show 3-5 PSI on the line for 15 min on new installs and red tags. Turn-ons they do a dial test for 15 min. No supplier here will do the line pressure test.
Mystery - leak or no leak turness Plumbing 4 01-12-2013 08:46 PM
Fixed water leak now low pressure whitecrow Plumbing 15 08-13-2011 12:36 PM
Low water pressure after fixing leak. SirDrums Plumbing 5 06-09-2010 11:04 AM
Pressure leak loyal Plumbing 1 04-06-2009 10:30 PM
Leaking pressure relief valve Chris Magee Plumbing 12 08-12-2008 08:48 PM
