Old 12-17-2007, 12:51 PM   #1
Gas Furnace
"My Bryant gas furnace runs on and off
I have it installed just last year , when I turned the thermostat on the unit runs for 1 min the shuts off for less that a minute then runs again for aminute then shuts off again , doing the same cycle all over again , it does not run continuously to build up the desired temperature, I have hot water running on baseboards, heated by natural gas. Please help
ERICZAP is offline   Reply With Quote
Old 12-17-2007, 01:05 PM   #2
Gas Furnace
Is this a furnace or boiler?
redline is offline   Reply With Quote
Old 12-17-2007, 07:28 PM   #3
Gas Furnace
sorry you are right this is a boiler
Old 12-18-2007, 06:32 AM   #4
Gas Furnace
Call the company that installed it. It should be under warranty.
Heil Furnace Burner Problem timothyr HVAC 78 01-18-2013 07:49 PM
Furnace Help tuasoi HVAC 2 11-29-2007 01:54 PM
furnace and or electrical problems tuasoi General Discussion 4 11-29-2007 01:50 PM
Replacing My Furnace, few simple questions compression HVAC 10 02-03-2007 06:00 PM
Could installing a furnace to the floor joists cause the floor to slope? JKL HVAC 5 01-03-2007 10:23 PM
