Gas Fireplace Vs Furnace? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-03-2010, 01:16 PM   #1
gas fireplace vs furnace?
I have about 750 sq place with bedroom doors clo
sed and windows that are energy efficient ones. The whole basement as well as onother 800 squar feet of the not does NOT need the heat if would receive if I had the furnace on. Therefore am I using less gas, just heating my kitchen and small living spasce? F/P has electric fan) The temp in the house with f/p on all night remains pretty much the same as when I shut if off while the thermostat for the furnace remains down at 15.
Liquidation is offline   Reply With Quote
Old 12-03-2010, 02:51 PM   #2
Rewards Points: 5,332
Can you reread this and edit it to be clear.
I have no idea what you're trying to say.
Ron
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
New Furnace or Fireplace Insert actegratuit HVAC 1 09-06-2010 07:49 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
