Gas Fireplace Problem - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-01-2010, 05:29 PM   #1
Question
I'm not sure if this is the right area for my question. I just moved into a house. The gas fireplace leaves a trail of soot up the front of the fascia and mantle. The gas fire seems to be very close to the front edge of the fireplace. The flue is open. This happens every time I use the fireplace, even at a very low flow rate. What can I do? (Majestic insert fireplace.)
Thanks in advance! Sandra
garridosk is offline   Reply With Quote
Old 01-01-2010, 09:21 PM   #2
Rewards Points: 5,336
I'd have a professional look at this. Chimney restrictions, incorrect gas volume, incorrect installation could all contribute to your problem.
I wouldn't use this device until it's been fixed.
Ron
Old 01-08-2010, 06:39 AM   #3
Call a pro, if you're getting soot in your home, you're getting carbon monoxide too.
log_doc_rob is offline   Reply With Quote
Old 01-08-2010, 04:46 PM   #4
Thanks for the responses!
Thanks so much for the responses. I've been worried about whether this was a carbon monoxide risk. I also smell the gas when the fire is lit and was wondering if I was just being paranoid. I will definitely stop using it until I have it looked at.
Sandra
Old 03-07-2010, 10:39 PM   #5
Sounds like it is not drafting properly.
ausblake is offline   Reply With Quote
[Pics Inside] Unsure what this part does (electrical fireplace switch) rdiggidy Electrical 4 09-07-2009 06:14 PM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 06:12 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
