Gas Fireplace Clearance - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-21-2013, 10:04 AM   #16
Rewards Points: 396
Originally Posted by joecaption View Post
You can go on line and see the exact framing and clearances that needs to be done.
I used to do all the enclosures for my local gas company and they would hand me a 3 or 4 page print out of how it needed to be framed.
All of them suggested steel framing and 5/8 fire rated drywall.
can't you use wood studs for the jack studs and header then wrap them with steel studs since the wood studs can fit inside the steel.
detroittigerfan is offline   Reply With Quote
Old 12-21-2013, 10:06 AM   #17
Rewards Points: 396
plus metal studs cant support a header.
Old 12-21-2013, 10:12 AM   #18
AHH, SPANS!!!
Rewards Points: 1,166
heavy gauge exterior metal studs can hold a header
hand drive is offline   Reply With Quote
Old 12-21-2013, 10:16 AM   #19
Plumber
TheEplumber's Avatar
Rewards Points: 834
I have worked in multiple buildings framed with steel studs- bearing and non-bearing applications. They can do anything wood can including headers. You have probably only seen light gauge material which has limitations.
Old 12-21-2013, 11:37 AM   #20
Rewards Points: 396
Is the header normally wood when using steel studs?
Old 12-22-2013, 08:14 AM   #21
AHH, SPANS!!!
the same heavy gauge metal studs used for the walls and track will be used in the header in a heavy gauge steel stud wall. it is a whole other ballgame when compared to wood framing but the same principles apply...
Need tile around zero clearance fireplace? novahall Interior Decorating 1 11-02-2013 09:26 PM
Fireplace reno help, wood to gas fireplace jsunsun Building & Construction 4 01-15-2013 08:09 PM
How to go about replacing fireplace surround? NewHomeDIYGuy Remodeling 9 01-26-2012 09:56 PM
Fireplace clearance kutsyy Building & Construction 1 01-04-2012 03:42 PM
Possible to build direct-vent fireplace? DIYerself General DIY Discussions 3 12-22-2007 10:07 PM
