Gas Fireplace Bump Out Construction? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-03-2012, 08:59 AM   #1
gas fireplace bump out Construction?
hoe do I construct a bump out for gas fire place?
JDONE is offline   Reply With Quote
Old 09-03-2012, 11:33 AM   #2
Rewards Points: 12,830
Is this a new fireplace you just bought?
If so look in the manual, or go on the companys web site.
It will show you diagrams and clearances needed to build it.
Most suggest using steel studs, and 5/8 fire code sheetrock.
Old 09-03-2012, 11:59 AM   #3
Framing Contractor
You're talking about bumping out past the exterior wall right?
Joe Carola
Joe Carola is offline   Reply With Quote
gas fireplace smoking? cbzdel General DIY Discussions 4 11-23-2011 08:53 AM
Fireplace Smell ...help wanted ! jasonb72 General DIY Discussions 6 08-26-2010 07:02 PM
placement of plasma tv kidsdrs Building & Construction 4 08-11-2010 12:21 PM
flooring around a fireplace. liquidvw Flooring 3 07-25-2010 03:23 PM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 07:12 PM
