Garages - Can They Be Made Mouse Proof? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-25-2011, 05:36 PM   #1
Garages - Can they be made mouse proof?
To those who live in rural areas, every garage eventually gets mice inside. 95% of the time the entry is made via the large car entry door through the gaps on the side and bottom rubber moldings. It only takes a 1/4" gap for a mouse to squeeze through. The remaining 5% of the time entry is made through the walls.
Is there ANY WAY a garage car entry door can be made mouse proof? Or is it inevitable due to the large door opening and the subsequent rubber seals that can only do so much?
JackOfAllTrades is offline   Reply With Quote
The Following User Says Thank You to JackOfAllTrades For This Useful Post:
gstay (09-23-2012)
Old 11-25-2011, 06:29 PM   #2
Rewards Points: 150
You could dato the concrete out by the thickness of the garage door then adjust the door to fit into the channel. Then wrap the bottom two feet of your garage in live cats....
OhioHomeDoctor is offline   Reply With Quote
The Following User Says Thank You to OhioHomeDoctor For This Useful Post:
woodworkbykirk (11-25-2011)
Old 11-25-2011, 06:37 PM   #3
Rewards Points: 2,240
Mice are a little smarter than you think.
Seen them wait until someone opens a door - in like a flash!
Probably, faster then the "normal" person would notice.
CAT!
rossfingal
rossfingal is offline   Reply With Quote
Old 11-25-2011, 07:49 PM   #4
DIY staff
Rewards Points: 7,174
Bud Cline has a knack for getting rid of mice----
Old 11-25-2011, 08:11 PM   #5
Too Short? Cut it Again!
I know some were in part joking but something is to be said for well trained feline mousers that like the work. I've had cats that truly did although they were not about to eat the things---just played soccer with them until the mice died of cardiac arrest. The the trophies got delivered into a slipper or something.
I read somewhere that the LA Police department has a real problem with mice in some precincts. They worked out some sort of scheme where they work with the SPCA to provide food and water for relocated ferile cats to work the perimeter of the buildings. I guess it is working. The cats are sterilized but this arrangement lets them live out there natural lives and saves them from having to be put to sleep.
Not to insult intelligence but part of the deal in minimizing infestations is to make sure they have limited reasons for hanging around. Make sure stuff like grass seed is in tight sealed plastic containers---they will chew through boxes and plastic bags.
Some say stuffing ingress/egress points with steel wool can be helpful. I never found it to be effective. There comes a point where you may have to call in an exterminator. When living in Santa Clara County California field mice were over running homes largely because housing development was destroying their natural habitats. The same development eliminated their predators as well. The County handed out bait for free to try to gain control. It worked as long as everybody in the neighborhood participated. One person or property trying to fix things on their own is not going to get far.
Old 11-26-2011, 12:37 AM   #6
So in other words, NO, a garage can never be sealed completely to prevent mice from entering. Oh well, I thought there might be a new design but apparently garage doors, like French Doors, never seal 100%.
Old 11-26-2011, 12:51 AM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 1,984
That is correct....they brought in some ferile cats...mouse problem was solved in a matter of weeks.
We have cats....2 of them......
A couple of years ago I was coming home late (3am)....walked up the drive and saw one of our cats on the driveway looking at a box next to the house. Normaly this cat jumps up and wants attention....not this time...she keeps looking at the box.....hmmmmmm....I kick the box....nothing....I kick it again....a mouse runs out....right towards our cat....she reaches out...grabs the mouse....places said mouse in her mouth....looks at me with that "thank you" look....and calmly walks away to enjoy a 'warm meal'.
Old 11-26-2011, 11:18 PM   #8
I wonder if this has actually been done. It makes sense but is it feasible?
The garage door would esentially sit within a "U" channel. The question is if this concrete channel would be ABOVE grade or BELOW grade? Above grade, it would cause a lip but below grade it would be a place for water to sit, so I assume ABOVE grade would be the better choice.
Old 11-27-2011, 01:31 AM   #9
Rewards Points: 384
Our cats would start at the head and work down to the tail.
Cats do work, but bull snakes work better. My brother and I had a cage for small animals. We sometimes kept snakes in the cage. Nice thing about snakes, you don't feed them. When they got hungry enough, they crawled out and took care of the rodents.
fireguy is offline   Reply With Quote
Old 11-27-2011, 06:33 AM   #10
DIY staff
I like the idea of snakes----that might keep thieves and neighbors out of the garage,too.
" Please don't step on the snakes" That sign on the door would work wonders!
Old 11-27-2011, 10:17 AM   #11
Rewards Points: 120
Until about two years ago, we had varying degrees of success with cats in my shop. A couple of them were great hunters, but watching a few of the others try to catch anything that wasn't already in there food bowl was nothing short of hilarious. Last summer though I had noticed the absence of any mice in the shop, and didn't think much of it until I found a couple of traps that looked like they had mice pulled out of them. Within a few weeks the mystery was solved when I came literally face to face, at only a few feet, with an about 5' long rat snake that was wrapped around a joist. Well, seems that he had the problem under control. Only problem is that I hate snakes, so I'm back to traps.
Old 11-27-2011, 11:02 AM   #12
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Cats are one answer. Keep in mind it takes training to be a good mouser.
Really!
While all cats have the instinct, it takes training from the mother cat to develop the kill ability. Otherwise, like my cats, they often just play with them.
Old 11-27-2011, 06:04 PM   #13
Add some rattle type sound effects on a sensor and you will have the problem in hand. I was 10 when we lived in Cheyenne and rattlers were prevalent to the point they blew them off the pavement with dynamite with dynamite because they were slippery. I never knew anybody who was bitten but if I heard one walking around I would not leave the house for days!
Old 11-27-2011, 08:30 PM   #14
No they can not!
Due to having to empty all 6of my traps DAILY, and running out of peanut butter... I just picked up a pair of barn cats from the local shelter. We are crossing our fingers they dont run away
illnastyimpreza is offline   Reply With Quote
Old 11-27-2011, 10:13 PM   #15
You could run a separate 20 amp service, install a bunch of extra outlets, and plug those worthless ultrasonic things in. I just giggle when I see people buying those. Aren't they still like $10? $12 if you want a model with blinking lights. A friend introduced one of the first acoustic modems to the market. People didn't trust that it was working until they added blinking lights. The lights had nothing to do with the circuitry---they were just blinking red and green lights. Sales took off though. How about "De-Mouser on a Stick?" People will buy anything if you offer it on a stick.
It is 90 percent urban legend because it did not last long. Pigeons are rats with wings but not stupid. For a time though, the AT&T janitor that fitted the circular arch thing atop the building with plastic owls, was a hero. They at least made the pigeons take a second look for a time. I wonder if rubber snakes would scare the mice?
Of course the birds of prey program in NYC is really working well. Somebody got the bright idea to provide habitats for hawks, falcons and other type hunters on top of skyscrapers. I don't think eagles did so well. They seem to be adapting, nesting and reproducing in place. They hunt pigeons and rodents at night. The "Save the Pigeon" people remain aghast of course.
Milwaukee tool made in China KUIPORNG Tools 63 08-31-2011 01:10 PM
Tools and equipment NOT made in china? TheVampire Off Topic 11 09-15-2008 07:25 PM
Making Stairs Scratch Proof 1simple Flooring 1 05-22-2008 01:12 PM
Help! Our contractor made our kitchen cabinet door stain TOO ORANGE! Nikki99 Painting 12 11-19-2007 11:45 PM
Some modification of mouse. DeepOne PC Repairs & Upgrades 4 06-16-2006 12:32 PM
