Garage Wall Moisture - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-28-2013, 10:31 PM   #1
One of the walls of my garage has moisture seeping through. It is a cinder block wall. The exterior of this wall is a contained planting area so there needs to be some sort of drainage (a french drain perhaps) installed to get the moisture out of the area. My question right now is, how big of a deal is it to have moisture on this wall during wet periods of the year? Will it eventually cause the wall to deteriorate? Should this be addressed immediately or can it stay as-is for awhile?
Thanks for your help.
johnfrederick is offline   Reply With Quote
Old 03-28-2013, 10:37 PM   #2
Rewards Points: 13,694
Got a picture?
That wall should have been waterproofed on the outside.
Over time yes it will weaken the block and morter and cause mold to formo the inside.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
johnfrederick (03-29-2013)
Old 03-29-2013, 07:24 AM   #3
Rewards Points: 4,640
dig out the planting area to below the garage floor + 1' - more if its a block wall,,, trowel on fiber-reinforced roofing cement & protect that w/pond liner,,, you may also need to install a catch drain leading to daylight,,, replant taking care to have positive drainage just like joe sez
stadry is online now   Reply With Quote
The Following 2 Users Say Thank You to stadry For This Useful Post:
GBrackins (03-29-2013), johnfrederick (03-29-2013)
Old 03-29-2013, 10:58 AM   #4
Roofmaster
Rewards Points: 2,210
Yes, you are going to want to waterproof the outside of that wall, I would prime it and put up a peel and stick SBS material. Were I you, I would add a drainage pipe at the bottom, geotextile drainage board like Miradrain 6000 against the wall over the waterproofing fabric side out, clean stone around the perforated pipe, and poly over the stone to prevent blocking.
Cinder block will fall apart, as Joe said.
The Following User Says Thank You to jagans For This Useful Post:
Moisture on Garage wall bryanp22 Landscaping & Lawn Care 10 03-18-2012 08:47 AM
Adding external wall sconces to attached unfinished garage FremontJoe Electrical 2 03-07-2012 02:53 PM
Garage CMU partial wall - shifted block ChrisJJ Building & Construction 9 04-01-2011 12:27 PM
Frost Build Up On Interior Garage Wall richw Building & Construction 8 01-06-2008 09:47 AM
Replacing Wall in Garage viking1974 Building & Construction 3 08-10-2007 10:23 PM
