Garage Wall Leaning Out - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-12-2007, 08:02 AM   #1
Garage wall leaning out
A side wall on my garage is leaning out about 4" at the top. Is there a way to push up on the center of the roof and pull the wall back to verticle, then brace the roof so it wont happen again?
billdiy is offline   Reply With Quote
Old 04-12-2007, 09:27 PM   #2
Yes, attach a cable at the top of the plate, on both sides, use a turnbuckel between the cables, use this to draw the walls plumb, and at same time use a couple of house jacks to push up on the roof, this will require for you to slowly, when your building creaks stop, let it settle a day or so and do it again, until your walls are plumb. once they are plumb install collar ties, this should keep your walls from spreading again. You may have to use more than one set of cables and turnbuckels.
Gary
gary is offline   Reply With Quote
Old 04-15-2007, 03:29 PM   #3
Rewards Points: 5,336
You could also jack up the ridge beam to take some of the weight off the walls. Might make it easier to pull them back in.
Ron
Old 03-19-2010, 01:38 PM   #4
I am having a similar problem and was considering building a dummy wall in front of the existing with 2x6 and lag bolts attaching 2x6 to the leaning wall and then to the existing sturdy roof rafters.
Nickm is offline   Reply With Quote
Old 03-19-2010, 02:24 PM   #5
Proper way has been outlined
Jack up the middle of the roof while pulling the wall(s) back in
Attached or detached ?
Only one side is leaning out ?
Old 03-20-2010, 05:07 AM   #6
detached garage, only one wall is leaning.
Old 03-20-2010, 10:34 AM   #7
thats not making sense unless footing sinking. are there collar ties now, is wall leaning a rafter wall
The older I get the better I was
Old 03-20-2010, 04:36 PM   #8
Rewards Points: 4,454
if it were the fnd settling, both walls would lean UNLESS the ridge beam was angling & there're no collar ties, no ?
Old 03-20-2010, 09:10 PM   #9
One side wall is separating from the back wall at the top. This separation is causing the rafters to split and detach from the ridgeboard.
Old 03-20-2010, 09:13 PM   #10
sounds like settling if only one side is tearing loose
Old 03-22-2010, 05:09 PM   #11
waterman1971's Avatar
Rewards Points: 150
Collar ties must be located properly. If they are not you may end up with thrust.http://www.unified-eng.com/ch/thrust.htm Is the any corner bracing in the walls perpendicular to the problem wall? Seems like both walls must be leaning. If only one wall is out of plumb it should be separating at the top or bulging in the middle. Hope this makes sense.
waterman1971 is offline   Reply With Quote
Old 03-22-2010, 08:08 PM   #12
yep he said rafters are pulling loose thats why i thought sinking
Replacing Wall in Garage viking1974 Building & Construction 3 08-10-2007 11:23 PM
Help Repair Garage Wall - Advice RandomJustice Building & Construction 8 07-28-2007 11:02 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Leaning Garage jocaan Building & Construction 4 05-13-2006 10:32 PM
