Old 04-25-2007, 03:46 PM   #1
Default Garage Wall Board
I got samples of this new interior exterior wall board material that looks excellent. It sells direct to consumers by full pallets delivered to anywhere in North America when there are no stocking retailers in an area. I want to use it to do my garage interior using a brad nail gun. Has anyone used it?
Joe J.
Last edited by AtlanticWBConst.; 04-27-2007 at 07:59 AM. Reason: Obvious advertising - contact site administrator to advertise
Joej is offline   Reply With Quote
Old 04-25-2007, 04:04 PM   #2
How much?
NateHanson is offline   Reply With Quote
Old 04-25-2007, 05:30 PM   #3
Tired, Cold, and Damp
slickshift's Avatar
...using a brad nail gun?
Can you do that w/drywall?
slickshift is offline   Reply With Quote
Old 04-25-2007, 11:29 PM   #4
Its about twice the cost of drywall to buy (comparing 5/8" vs 3/8"). But with the labour savings from being much easier to install with a nail gun, avoiding taping, corner bead and sanding, it should be a cheaper, faster and cleaner way to do wall boarding.
I tried my nail gun on samples and they hold much better than in particleboard. You can pry the board off the studs with a crow bar but the nails stay in the board not in the studs. The brad nails hold stronger in the magnesiacore than they do in to the wood studs you're nailing it to.
When I try that with particleboard the nails get pulled through the particleboard and stay in the wood studs instead.
Also there is no nail hole to fill afterwards. Only a small dint and slit that painters putty can fill as you do the primer. But I like the look of it and would leave it unpainted and not bother filling the nail holes. They blend in to the surface patern of the boards.
Old 04-26-2007, 08:05 AM   #5
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
You came on this forum for the sole reason.....to speak about this product that you haven't actuallu used anywhere.....but, claim that you tried nailing a sample.....????
That's alot of effort to put into a product that you 'discovered', but have not actually ever installed anywhere .......
BTW- Anyone like processed meat?
- Build Well -
Old 04-26-2007, 08:44 AM   #6
I am looking to see if anyone else has gotten samples and used the product. It look's like great stuff and much better quality wallboard than drywall. Cost more than drywall but so does everything else. If it saves time and labour and gets a better quality job done that lasts longer, its worth looking into.
Yes I got sample 9" x 12" that are 1/4", 3/8", 1/2" and 5/8". I also got a small corner piece that is made up with brad nails that is filled without any taping or corner bead. I tried nailed the samples on studs with my own brad nail gun. I took a crow bar and pried the samples off the studs. The nails stay in the magnesiacore. The nails did not pull through the board (like they do with particleboard paneling). The nails pull out of the wood studs and stay in the board. The board was not damaged by prying them off with a crowbar and I could reuse them by sniping off the nails.
More On This Topic
Hi Tim Eaton with Expert Village. The next step now that we are back in the front side of the fence is going to be to nail these boards back in. we have replace the rotten wood on the back as you could see our new board down there now. Normally when you... Read More »
Hi this is Jon on behalf of Expert Village, in this video clip I will show you how to prepare our wall studs. On our Styrofoam installation our wall studs fall behind this diamond line. In addition the studs falls where the Styrofoam pieces fit together... Read More »
Hello, this is Matthew Christian from Tampa, Florida and on behalf of Expert Village, today we're here to talk about cordless nail guns. Okay, so we've armed our nailer here, we have the gas cylinder installed, we have our battery installed and we... Read More »
This is Rob McManhon for Expert Village. To avoid splits you want to stay inside from the edge of the wood. The closer you are to the end the more likely it is for you to get a split. Here we are going to intentionally split. I'm about three quarters of... Read More »
Bob Street with Houdini Home Repair on behalf of Expert Village. We are working on the trellis again today, a little overcast but we are going to deal right with that. What we are going to do is take a nail gun. You saw where we cut the boards earlier... Read More »
Replacing Wall in Garage viking1974 Building & Construction 3 08-11-2007 12:23 AM
Help Repair Garage Wall - Advice RandomJustice Building & Construction 8 07-29-2007 12:02 AM
sound board on ceiling of garage. scapriss Building & Construction 0 05-14-2007 01:57 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 11:47 AM
Cracked cement stem wall in garage pen2paper Building & Construction 0 11-28-2006 03:29 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
