Garage Wall Of 3/4 A-C Plywood - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-06-2012, 08:06 PM   #1
garage wall of 3/4 A-C plywood
I am just finishing a barn/garage that i built..all the walls are open cell spray foam....now i am going to put up ply wood wall (8 feet) and want to know what can i paint them or protect them with...they may get wet from time to time
stevieb
stevieb827 is offline   Reply With Quote
Old 07-06-2012, 09:04 PM   #2
Rewards Points: 13,724
If this is an enclosed garage why is it going to get wet?
No plywood or paint will hold up that well under those conditions.
Old 07-06-2012, 11:09 PM   #3
GBrackins's Avatar
Rewards Points: 2,108
are you talking about installing plywood over the spray foam on the interior as a means of protecting the foam from heat and/or flames? or are you asking about an exterior application?
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
The Following User Says Thank You to GBrackins For This Useful Post:
oh'mike (07-07-2012)
Old 07-07-2012, 07:04 AM   #4
AHH, SPANS!!!
Rewards Points: 1,166
use pressure treated plywood if moisture is an issue...
hand drive is offline   Reply With Quote
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 4 04-04-2017 07:38 PM
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Partition Wall in Garage - Need footer? cmarlo Building & Construction 6 03-30-2011 07:30 AM
Garage brick wall repair TANME General DIY Discussions 2 02-04-2010 06:19 AM
Replacing Wall in Garage viking1974 Building & Construction 3 08-10-2007 10:23 PM
